Thread: Axial 56T Spur on stock Wraith kit doesn't fit?
Old 01-06-2018, 10:50 AM   #1
Default Axial 56T Spur on stock Wraith kit doesn't fit?
Apparently this doesn't fit on my stock wrath slipper?
Axial Racing - Spur Gear 32P 56T
I drilled the 3 holes through the spur, but the stupid center hole is too big and and the spacer they give you is the wrong size?
Ugh.
Digital is offline   Reply With Quote
Old 01-06-2018, 12:39 PM   #2
Default Re: Axial 56T Spur on stock Wraith kit doesn't fit?
Yep. Sounds like you have the original single disc slipper, that spur only works with the later dual-disc slipper found on the Wraith Spawn/Poison Spider/Yeti/etc. If you don't want to update with the newer slipper (you'd need a new top shaft, 2 discs, spacer, and 2 pressure plates) you can use a spur from a Duratrax Evader (if you can find one, they just got discontinued) or a Traxxas Slash. Robinson Racing also makes a steel spur that will fit.
TheLetterJ is offline   Reply With Quote
Old 01-06-2018, 12:40 PM   #3
Thanks for the reply TheLetterJ, appreciate it.
Old 01-06-2018, 05:29 PM   #4
Would this fit? Traxxas 3957 56-T Spur Gear (0.8 metric pitch, 32P) https://www.amazon.com/dp/B000BP63ZK..._CNwuAbV26BRZ7
Sent from my Tin Can using Tapatalk
Old 01-06-2018, 07:16 PM   #5
I've only read that the Traxxas spur will fit, I have not tried it myself, so you'll have to wait for somebody else to chime in on that. I have run a 54t Kimbrough spur (#129) and the Robinson 58t steel spur (#1558, not their complete slipper conversion.)
Old 01-07-2018, 09:00 AM   #6
So this one maybe?
https://www.towerhobbies.com/cgi-bin...SABEgKokPD_BwE
Axial 56T Spur on stock Wraith kit doesn't fit? - Similar Threads
56T spur what T pinion? GTSLOW Axial Wraith 2 10-16-2015 06:28 AM
32P 56T Spur Gear Robny Axial Wraith 3 01-13-2014 12:47 AM
RRP 56t hardened spur stpete40 Axial SCX-10 0 01-27-2013 12:21 PM
