They're in the cart and my finger is on the button https://www.rpphobby.com/ProductDeta...69-00&CartID=1 https://www.rpphobby.com/ProductDeta...55-00&CartID=2 I'm weak. There needs to be a RC Anonymous. |
Re: They're in the cart and my finger is on the button You're in the wrong place for an intervention haha PUSH THE BUTTON! Sent from my HTC One_M8 using Tapatalk |
Re: They're in the cart and my finger is on the button I did they're on the way. |
Re: They're in the cart and my finger is on the button Good thought you weren't going to jump but glad you did :) Happy Crawling, trailing, missing or whether your going to do with your new parts! Sent from my HTC One_M8 using Tapatalk |
Re: They're in the cart and my finger is on the button Quote:
Re: They're in the cart and my finger is on the button No it's not you I too had a couple of goodies in that cart and the screamed at me....cross country !!! So the Puller Pro is coming south on Monday Hang up and Drive |
Re: They're in the cart and my finger is on the button We'll I haven't had anything in shopping carts but couldn't resist pulling the trigger on 2 used rigs haha should've just added some cheaper shopping cart stuff! Thanks for being a good influence :D Sent from my HTC One_M8 using Tapatalk |
Re: They're in the cart and my finger is on the button My pleasure is your good fortune ! Besides you will need the cart to "fix" those two...... Hang up and Drive |
Re: They're in the cart and my finger is on the button Looking forward to hearing your thoughts on the slate motor. That's such a great price for the specs this motor has. I'm dying to try one myself. You chose wisely on the ESC for sure. |
Re: They're in the cart and my finger is on the button It has some big shoes to fill. I chose it over a Holmes Puller Pro because of the price and Harley's thoughts on it. The esc was a no brainer. I have a MonsterX in my Yeti and it's a beast. From what I've read the MambaX isn't far behind it and my Wraith is a lot lighter than my Yeti......so far lol |
They're in the cart and my finger is on the button I looked very long and hard. I have a 17.5 Tekin (2pole) and I am very impressed with it for crawling. Where it sucks is when stuck in a hole with grip and a clear shot, NO torque sucks. That is why I did the PP. I run a Pro4hd in the Yeti and it is impressive. I will find out tomorrow , RPP is coming. I just didn't know about the slates torque, PLEASE let us know ! Hang up and Drive |
Re: They're in the cart and my finger is on the button I have a Puller Pro XL in my Yeti I think it would rip the tires off the rims before it stalled. Torque will not be a problem for you there. |
Re: They're in the cart and my finger is on the button Oh I know about that XL, cannot imagine even fitting in the wraith . I almost went stubby, but it should fit @ 53mm Hang up and Drive |
Re: They're in the cart and my finger is on the button WOW VIOLENCE Insane Torque ! I see the Puller Pro is real, I suspect it's the big 17mm armature. I'm glad I pushed that button !https://uploads.tapatalk-cdn.com/201...3a181f99df.jpg Hang up and Drive |
Re: They're in the cart and my finger is on the button MIPs , RR 32p on a bulletproof trans , all but 6mm outputs. HD gears in SSD housings, all new fast Eddie bearings, and NO 4s. The ruptures have incredible bite, my new servo is a letdown .... nowhere near 400 oz, closer to 300. All VP chubs and knuckles. I'm hoping it will stay together, time will tell ! Hang up and Drive |
Re: They're in the cart and my finger is on the button I'm going to try to stick with plastic axle housings and the stock drive shafts see how the work out. I can see this escalating quickly just like the Yeti. The big difference between the two is that the Yeti was meant as a modded to the hilt project from the start. This Wraith was supposed to be a simple almost out of the box project. Oh well. |
Re: They're in the cart and my finger is on the button Stock driveshafts (WBHDs) are fine and so are the stock axle housings. It's the HD ring and pinion and HD trans internals you'll need. $50 for front and rear axle gears and $30-$40 for trans gears and you'll be all set. Universals are a good suggestion if you don't have them already. |
Re: They're in the cart and my finger is on the button The motor and esc came today. The MambaX is better looking than the MonsterX not that it matters. |
