Thread: wraith body panels bolt on spawn?
Old 09-19-2017, 05:10 AM   #1
Default wraith body panels bolt on spawn?
Does anyone know if wraith spawn and the reg. wraith roll cages or frame is the same? I want to pick up some aftermarket wraith body panels for my spawn. will they bolt right on? thanks
spawn47 is offline   Reply With Quote
Old 09-19-2017, 05:37 AM   #2
Yes. I've got two Wraiths. One I run body panels on and the other a Spawn RTR body. You'll need at least some m2.5 bolts to mount them with. m3 may work, but you'll need to open the holes some or it could tear the plastic. I think they're actually m2.3 in stock form.
Brake Weight is offline   Reply With Quote
Old 09-19-2017, 06:47 AM   #3
Default Re: wraith body panels bolt on spawn?
There are a couple of places on the doors of Wraith panels that are supposed to go into holes already used for mounting the Spawn interior. Other than those few holes, everything works fine.
svt923 is offline   Reply With Quote
Old 09-24-2017, 04:53 PM   #4
great thanks
wraith body panels bolt on spawn? - Similar Threads
Wraith Spawn 3D printed bolt-in battery/electronics relocation Slovenian6474 Axial Wraith 15 01-10-2016 08:48 PM
