Replacement gearbox?? Hi guys!! THe screws of the gearbox of my Wraith doesn't lock properly... I guess it's kind of plastic material, and after change the motor many times the thread is not in good condition... I would like to change the plastic gearbox case for an alu case or something like that... Can you gimme some advice about what case should I buy please?? Thank you so much!!! |
Re: Replacement gearbox?? You can try some m3 brass inserts. |
Re: Replacement gearbox?? Aluminium SCX10/AX10 styles trans cases would be a good choice for long run, however you also would need longer locked diff spool like this one from hot racing https://www.towerhobbies.com/cgi-bin...?&I=LXGSCJ&P=7 or buy hot racing Wraith style aluminium case for direct swap "thumbsup" |
Re: Replacement gearbox?? VP makes a sweet aluminum case. Super Shafty uses them for the bulletproof trans. Hang up and Drive |
Re: Replacement gearbox?? Hi guys, thank you so much for your tips... It's not a good month for my economy, so I bought this one... https://www.ebay.com/itm/Xtra-Speed-...72.m2749.l2649 I hope to know how to mount everyhting with my parts... I'm scared!! Thank you so much again!!! |
Re: Replacement gearbox?? |
Re: Replacement gearbox?? Just buy what you can afford. I'd love all VP parts but it's not in the cards. I have a mix of everything. On softer aluminum, I find that it's better to use locktite on everything and just snug them. |
Re: Replacement gearbox?? Plus one on the Hot Racing. I have three of these Trans in my rigs and they've all been bullet proof running on Brushless, 3S. |
Re: Replacement gearbox?? I use the VP case, with the HR gears. HR has upped their game in the last few years. Hang up and Drive |
Re: Replacement gearbox?? Quote:
Re: Replacement gearbox?? I’ve got a lot of HR parts on my slashes, the quality was very erratic at best. About 2 yrs ago, something changed for the better. Hang up and Drive |
