Fricker08’s Wraith(s) 7 Attachment(s) Hey what’s going on guys, been into Rc’s for quite some time now. Raced everything from nitro stadium trucks to 1/5th scales and all in between. Decided to pick up a crawler and do some hiking and driving up here in the PNW. Anyways I would have liked to pick up a kit but seeing as it’s discontinued I opted for the spawn. I did a lot of reading on here and research before buying so I knew a couple things needed to happen right off the bat. Unfortunately after my first test drive about 15-20 min the stock motor was toast.. contacted axial with no real resolution so I replaced it with an Rc4wd 35T because that’s what the LHS had in stock. I haven’t had a chance to go test it yet though. I started with an aluminum steering servo Horn and looking into a battery relocation. I’m running an EcoPower 2s 5000mah pack. Unfortunately the newest spawn version with the waterproof receiver box isn’t so easy to relocate. I ended up cutting the receiver box mount for clearance and drilled a couple holes in the battery tray and secured with zip ties. Next I used the SMT receiver box mount to relocate the receiver to the rear where the battery sat. It required the use of a servo extension for steering and will require another for the esc when I relocate it up front. I like the look of the box up high in the back, kind of like a tool or cargo box. The modification require was minimal only having to drill 2 holes and using some screws from the chassis brace removed in the battery shuffle. Next I did the axial setup on the shocks, 3 hole pistons black springs and 30wt oil. I haven’t had a chance to test it but I have a feeling I will go stiffer on the springs. Anyways that’s a wrap for now, I’ve included some pics of the mods hope this helps someone out. |
Re: My take on a wraith spawn Looks nice. I just picked up a Spawn a few days ago, though I did own a Wraith Poison Spyder a few years ago so I'm somewhat familiar with the platform. I'll take a closer look at your pictures again to see whether I should consider relocating my electronics similarly. Thanks for sharing. I look forward to hearing what you have to say about the 35T motor. |
Re: My take on a wraith spawn Thank you, I will see if I can get some better detailed pics of what I did, and I will report back how the motor does when I get out to test it. |
Re: My take on a wraith spawn 1 Attachment(s) Quote:
As for the suspension I’m pretty happy with it as well. I think I’ll run the light springs for a while and see how it goes. When I got home my vanquish steering links showed up so I did some little changes and I’ll give her another run tomorrow. |
Re: My take on a wraith spawn Wanted to update on the status of the burned up stock 20T motor. I reached out to horizon and the shipped me a new one so hats off to them! |
Re: My take on a wraith spawn Quote:
Re: My take on a wraith spawn 3 Attachment(s) Haven’t posted in a while, haven’t really had a chance to drive it with the weather. But I got the vanquish steering links setup as well as swapping out the stock shocks for some 110mm eBay dual rates with functional bypasses. Took it to high rocks up here in Gladstone and had a pretty good time. Surprisingly happy with the eBay shocks after a little setup |
Re: My take on a wraith spawn Looking good! Sent from my SM-G975U using Tapatalk |
Re: My take on a wraith spawn 5 Attachment(s) Well I guess one wasn’t enough.. came across an early wraith for not a terrible price. Unfortunately the motor was shot same with the batteries but a rc4wd 35t motor and some juice she’s alive. Came with a set of rc4wd king shocks that need some love so I put the stock spawn shocks on it, ordered some body panels and have some vanquish steering links on the way. When I get some free time I’m going to go through the car completely new bearings and make sure the mechanicals are good then I’ll start the mod process 8) |
Re: Fricker08’s Wraith(s) Well my original wraith spawn and the other are long gone. Didn’t know where else to post this so here we are. Ended up making a mistake on a deadbolt bronco body so instead of trashing it I did some horse trading for a wraith. Trimmed the hell out of the body scabbed the dash and seats in the chassis and painted it cobalt green per the Gf’s request. Thought I’d run it in 2.2 form but when you’re bored and have a Capra laying around you get creative. I need to trim the front links to bring the wheel base in, but all in all I’m happy with it. Capra axles, transmission and suspension. Wraith links HW1080 trailmaster 35t savox 1210sg https://uploads.tapatalk-cdn.com/202...bb3fd69158.jpg https://uploads.tapatalk-cdn.com/202...b0cf984e28.jpg https://uploads.tapatalk-cdn.com/202...716dc557ca.jpg https://uploads.tapatalk-cdn.com/202...90aaefbe78.jpg https://uploads.tapatalk-cdn.com/202...c6b9f5b474.jpg Sent from my iPhone using Tapatalk |
Re: Fricker08’s Wraith(s) That looks pretty sweet man, nice job |
Re: Fricker08’s Wraith(s) It’s a hobby, so why not? Looks like a Wraith. It’s the Capra skid on there yeah? Looks good, like the Cobalt green. I have the Bronco body on my Wraith as well |
Re: Fricker08’s Wraith(s) Thanks guys, it’s the wraith skid, I’m just running 3/4 holes. Lined one up with the stock trans and drilled 2 more. I’ll be working on shortening the front links up today and figuring out a different chassis brace to clear the servo Sent from my iPhone using Tapatalk |
Re: Fricker08’s Wraith(s) Looks pretty good with those Capra axles under there. Love the color! |
Re: Fricker08’s Wraith(s) Looks really cool. Going to say something nitpicky though lol...would look even really cooler if the very front of the fender (up by the grill, bottom edge of the wheel arch) was radiused instead of a hard edge. May not look as "Bronco" ish but would flow better imo. Just a little massage with the dremel/grinding barrel :) Digging the color too |
Re: Fricker08’s Wraith(s) Hey thanks for pointing that out phildirt, I didn’t even realize how hard of an edge that was, I’ll be giving it a trim. I haven’t messed with the links yet, I’ve got a set of 2.2’s coming and I’ll likely throw the ar60’a back under it. I took it out today though, and for being a limo it performed surprisingly well. Here’s some pics https://uploads.tapatalk-cdn.com/202...3510311f98.jpg https://uploads.tapatalk-cdn.com/202...1bcc4c249c.jpg https://uploads.tapatalk-cdn.com/202...b71ef64821.jpg https://uploads.tapatalk-cdn.com/202...3945a57e26.jpg Sent from my iPhone using Tapatalk |
Re: Fricker08’s Wraith(s) sweet pics. cobalt green takes you to the tropics |
Re: Fricker08’s Wraith(s) Well here it is, back on ar60’s and with a hobbywing 540 axe 2300kv setup. I have some 2.2’s coming but I like the look and size of the 1.9’s with the flat iron xl’s. Got some softer springs coming and some chassis parts. Even though this is the standard wraith wheel base I still might shorten the front up slightly. https://uploads.tapatalk-cdn.com/202...852e971a5d.jpg https://uploads.tapatalk-cdn.com/202...eff79c574d.jpg https://uploads.tapatalk-cdn.com/202...7957c5eac7.jpg https://uploads.tapatalk-cdn.com/202...6cc5e25ebb.jpg Sent from my iPhone using Tapatalk |
Re: Fricker08’s Wraith(s) I think if you shorten the front some, maybe little bit narrower hubs on the wheels, and it'll look perfect with those 1.9s. Sent from my SM-G970U using Tapatalk |
Re: Fricker08’s Wraith(s) Quote:
That’s what I was thinking, I’ve got some lockeduprc .185 hubs in my cart and I’ve got slim wheel hexes. That would bring it in a little bit. Then just need to drill/tap and shorten up the front links about 1/4” Sent from my iPhone using Tapatalk |
