10-21-2010, 11:20 AM | #1 |
Quarry Creeper Join Date: Mar 2008 Location: Columbus OH
| rear slop
I'm sure most of you have noticed the side to side slop in the rear axles. I'm looking for tips on removing it. |
10-21-2010, 11:23 AM | #2 |
Rock Crawler Join Date: Feb 2009 Location: Chandler, AZ
10-21-2010, 11:31 AM | #3 | |
RCC Addict Join Date: Jun 2009 Location: California
Clean fix...They designed them so the slop is removed from the rear axle. | |
10-21-2010, 11:45 AM | #4 |
Newbie Join Date: May 2009 Location: Concord
I just used 5x8mm teflon washers from traxxas to get rig of the slop, you get 20 for $2.00 (TRA1985) and I used 4 on each side.
10-21-2010, 12:26 PM | #5 | |
| Quote: | |
10-21-2010, 12:39 PM | #6 |
10-21-2010, 01:12 PM | #7 |
Quarry Creeper Join Date: Jan 2009 Location: Rocklin
Just put shims on the end of the axle on the side of the locker... I used 3 axial shims on each side that came with the ax10 strait axle...
10-21-2010, 02:07 PM | #8 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
I put a washer on the end of each axle between the lockout and the hex. (under the pin) i each side. LOL i didnt want to have to open the axle? Last edited by BEELZEBOB; 10-21-2010 at 02:14 PM. |
10-21-2010, 02:11 PM | #9 |
Quarry Creeper Join Date: May 2008 Location: Clarkston
I used one 0.3mm shim each side. |
10-21-2010, 02:42 PM | #10 |
RCC Addict Join Date: Nov 2008 Location: Greece, sun, sea and rocks
I didn't do anything. This thing would still kick a$$ even if it had slop in every single screw. Seriously though I used some Kyosho shims (no idea which) on each side. |
10-21-2010, 05:08 PM | #11 |
I used a 0.5mm shim between the bearing and the axle on each side.
10-22-2010, 08:32 AM | #12 |
Quarry Creeper Join Date: Sep 2008 Location: Rocklin
I shimed the rear with Axial shims from the AX10 straight axle kit. A total of .7mm on each side.
10-25-2010, 08:32 AM | #13 |
Newbie Join Date: Apr 2008 Location: Papillion
Which is better a shim or a washer?
10-25-2010, 09:55 AM | #14 |
Pebble Pounder Join Date: Oct 2004 Location: San Diego
| Axial XR10 Tips & Tricks shim is much better. as it is made to an exating spec... washers are not.. |
10-25-2010, 10:01 AM | #15 |
W.Pa.C Join Date: Jul 2006 Location: sw pa
a shim is just a thin washer. most likely the washer will be to thick.
