11-26-2010, 07:39 PM | #1 |
RCC Addict Join Date: Feb 2006 Location: ccxc
| Steering,,,,,,
Testig toninght I noticed that the steering gets hung up A LOT....basically it will not even move if minorly bound. Never had this issue on my ax10. Servo is the hitec 403oz, Would going to a straight link possibly help?
11-26-2010, 07:59 PM | #2 |
Quarry Creeper Join Date: Mar 2008 Location: N. Ridgeville , Ohio
| Straight link helps , but extending the servo arm that attatches to the right knuckle helps ALOT , Vanquish sells one and so do a few other companies and vendors on this site . I just hacked up one of my own out of an old aluminum shock tower from a different RC car . Hope this helps , it did on mine . |
11-26-2010, 07:59 PM | #3 |
I wanna be Dave Join Date: Mar 2008 Location: Pacific Ocean
Running a longer arm on the knuckle at the drag link takes care of this issue. |
11-26-2010, 09:15 PM | #4 |
I am running the BWD one for stock rims and still have the issue
11-26-2010, 09:46 PM | #5 |
Are you running a BEC? If so what do you have the voltage set at?
11-27-2010, 05:05 AM | #6 |
Rock Crawler Join Date: Nov 2009 Location: Southern, IN
I polished the drag link starting with 600 grit sand paper on a block and ending with 1500 grit, now that thing slides buttery smooth. Make sure to round the edges of the drag link. |
11-27-2010, 05:22 AM | #7 |
Is it a new servo? It could just be tired.
11-27-2010, 08:32 AM | #8 |
Fairly new hitec. I did have it at 6v. I forgot to bump it to 7.4. I still think it will be an issue. I have the bwd arm and am going to convert to a single link.
11-27-2010, 09:16 AM | #9 |
Quarry Creeper Join Date: Mar 2009 Location: searching
how much longer are these arms vs. The stock steer arms?
11-27-2010, 10:03 AM | #10 |
I wanna be Dave Join Date: Oct 2007 Location: 801
There are 3 weak parts to the steering. Plastic Knuckles should be the first thing to replace. They flex and cause too much counter steer. Here 3 Piece steering needs to be eliminated and replaced with sold single tierod. Here Front steering link should be replaced and use stronger less flexible rod ends. Such as Traxxas. Here Once I replaced these 3 things I have tons of power to my steering. |
11-27-2010, 06:02 PM | #11 | |
2. ordered from you 3. already swapped to revo ends | |
11-28-2010, 01:55 AM | #12 |
Rock Crawler Join Date: Aug 2008 Location: Wine Country
| Just remember, the RX doesn't like 7.4v, I have heard people frying it with 7.4v, run a second bec to power the servo. I did this to power one of my winches on my scale rig.
11-28-2010, 02:05 AM | #13 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
11-28-2010, 07:35 AM | #14 | |
Quarry Creeper Join Date: May 2010 Location: Longmont, CO
11-28-2010, 09:07 AM | #15 |
11-28-2010, 09:15 AM | #16 |
Rock Crawler Join Date: May 2007 Location: Norwich
you'll see an improvement in the "slop" when you get rid of the stock three piece setup. You'll also lose some of the steering "lock-up" that happens at full throw.
11-28-2010, 09:37 PM | #17 |
RCC Addict Join Date: Dec 2005 Location: Tucson
