Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: Chaotic crawler lw question
Old 04-22-2012, 03:44 PM   #1
Default Chaotic crawler lw question
Okay guys here I go again asking more questions but what should my gc be for this chassis? Mine is at 3" at the front and 3 1/4" at the back (not the links measuring right under the screws for the pan at bottom) and I have big bore shocks that I limited so that only 1/2" of the shaft is out in the front, and 3/4" of the shaft is showing in the back, does this sound good? Should it be taller? I wanted the chassis so I could clear stuff better and is I could break over stuff better. Thanks for the help once again
XJkid93 is offline   Reply With Quote
Old 04-22-2012, 08:25 PM   #2
Default Re: Chaotic crawler lw question
stock chassis?
trig n tahoe is offline   Reply With Quote
Old 04-22-2012, 09:07 PM   #3
Chaotic crawler lw chassis, as the title says
Old 04-23-2012, 05:21 AM   #4
Sounds about right for a good starting gc, do some testing and adjust as low as possible but still allows for good clearance for your area. Not sure about the big bores, I run limited stockers.
OhioCrawler is offline   Reply With Quote
Old 04-23-2012, 08:51 AM   #5
the big bores rock thats what i'm running.3.5 front and 4" out back.
Ride height is 2 3/4" at front and 3" at rear. but i'm thinking the fron should be 3" for good break overs.
Hope this helps
chevotafun is offline   Reply With Quote
Old 04-23-2012, 01:49 PM   #6
thanks guys it really does,
Chaotic crawler lw question - Similar Threads
My Chaotic Crawler Build TakeNotes Axial XR10 60 11-18-2012 08:23 AM
Chaotic crawler lw chassis shock help XJkid93 Axial XR10 10 04-21-2012 08:27 PM
