12-29-2011, 08:58 AM | #1 |
Rock Crawler Join Date: Nov 2011 Location: Wister, OK.
| Width?
What width are you guys running from outside tire to outside tire in the front? Rear?
12-29-2011, 09:08 AM | #2 |
RCC Addict Join Date: Oct 2009 Location: Council Bluffs
| Re: Width?
im running right around 11 front and the rear is 10 7/8
12-29-2011, 09:55 PM | #3 |
| Re: Width?
Anybody else?
12-29-2011, 10:33 PM | #4 |
Rock Crawler Join Date: Sep 2009 Location: dartmouth ns
| Re: Width?
11" front 10 3/4" rear with 1" SLW wheels 475 front hubs and 600 rear. I am also running Losi wheel hexes which are a little narrower than the Axials maybe like 1/10"- 1/8". Hope this helps |
12-30-2011, 06:32 AM | #5 |
| Re: Width?
Is there a downside / upside of running wide in the front and narrow in the rear? By that I mean like 11 1/2" front and 10" rear? |
12-30-2011, 07:22 AM | #6 | |
| Re: Width? Quote:
Upside: Clearance on the rear when coming through gates and turning I run my trucks a bit narrower in the rear....but the difference is never more than 1/2". One other thing.....a wider truck is technically also longer in certain situations and can be helpful. Of course, there are those situations where it is a hindrance. Last edited by JeremyH; 12-30-2011 at 07:25 AM. | |
12-30-2011, 07:25 AM | #7 |
| Re: Width?
I'm going for as narrow as I can get with a 1 1/4" SLW wheels a personal choice for the tires I run. At the front to start with, I'm at 10 3/4" front 10 1/2" rear. But I'm just building my first XR, so it could get wider when it gets some run time. Seems lots of people are running them much wider. I'd like to understand why? So I'll be experimenting. . Crawler Design Works makes 1/8" and 1/16" wheel spacers for VP wheels so you can basically go anywhere you want to. |
Width? - Similar Threads | ||||
How to pick wheel width and track width, Help please | toy4crawlin | EnRoute Berg | 6 | 06-16-2011 09:59 AM |
XR-10 width | Chevdog | Axial XR10 | 5 | 06-10-2011 03:52 PM |
wheel width vs. tire width, and rust | boondocksaint | Tires and Wheels | 0 | 05-10-2011 04:11 PM |
Track width, vanquish rims what width and hbs? | Kraqa | RC4WD Bully | 10 | 01-14-2010 08:50 PM |
Axial Axle width vs WK axle width? | DaveFL | General Crawlers | 2 | 12-21-2007 01:11 PM |
