08-23-2010, 03:18 AM | #1 |
Quarry Creeper Join Date: May 2008 Location: Clarkston
| XR10 Servo suggestions
Hello Teamdrivers, since you have been testing the rig for the longest time I was wondering what servo you suggest. I put the 5955TG @6V in my rig, which is definately not enough. Even minor binds totally lock out the steering, since the servo through is so limited. What servos do you guys use with what voltages and what outside temperatures? Iīd really appreciate some feedback. Thanks, Uli |
08-23-2010, 03:55 AM | #2 |
Pebble Pounder Join Date: Apr 2009 Location: germany
I use the 7954SH on 7,2 V. The Servo goes very hot. That interestet me to... |
08-23-2010, 06:37 AM | #3 |
Rock Crawler Join Date: Feb 2008 Location: Dortmund, Germany
Hello, i'm running also A Hitec7954SH at 7.4V and it get's sometimes a bit too hot, so the overload protection comes in. The steering geometrics needs a strong servo, that's for sure. Maybe the Hitec 7950TG or the Savöx 1270TG is a way to go. Greetings Frank |
08-23-2010, 08:01 AM | #4 |
Rock Crawler Join Date: Jan 2007 Location: in my bubble
I smell a new steering set up..
08-23-2010, 09:34 AM | #5 |
Keep Crawling in Crawling Join Date: Jan 2009 Location: Commerce City
Becky's (Holy Roller) is running a Hitec 7950 set at 7.2 volts. Her servo gets hot while running. She back off her end points and that helped some. I know Sparky J runs a 7980 or a 7990, it is bigger in size but it will fit and it does not seem that his is getting that hot. The 7980 and 7990 at 7.4 volts has 611 oz., but the servo is slower than the 7950.
08-23-2010, 12:55 PM | #6 |
Quarry Creeper Join Date: Dec 2008 Location: Aurora Colorado
Tom, Why do you think the 7950 is getting hot in Becky's car? Did it get hot in her berg? I dont remember mine ever getting hot in my berg but to be honest I dont really check the heat of my servo. |
08-23-2010, 01:02 PM | #7 |
| I don't really know how hot the servo gets in the berg because of our steering set up. It is cut into the front axle housing and with it resting against the cut out in the housing the housing acts like a heat sink. It is also so tucked in between the axle housing and the motor that you can't really touch it. I am sure the extra heat from the servo could possibly be because of the way the steering is designed but I could be wrong. The only person I can compare it too is Sparky and he runs the 7980 or 7990 servo which is a larger servo.
08-23-2010, 03:06 PM | #8 |
Quarry Creeper Join Date: Jul 2009 Location: Derby
I was running the 5990tg in my berg and it got quite hot.. I've switched to the 7980 at 7.4v and it still gets warm, but nothing like the 5990.. I'm considering dropping the voltage on the 7980 to 7v to see if it helps with keeping it cooler..
08-23-2010, 03:47 PM | #9 |
Newbie Join Date: Feb 2009 Location: Germany
If you change the geometrie of the steering you will be fine. Shorten the servohorn and make the link from the servohorn to the knuckel longer, in neutral steering postition the servohorn should stand to the right side maybe 20° degrees. You have to try out diffrent link length.
08-23-2010, 11:46 PM | #10 |
Just curious as to if you guys are greasing the slider? By the looks of it, when the knuckles apply force to it (the slider), there'll be torque applied against the axle housing that it slides in causing binding. Just a thought. |
08-23-2010, 11:53 PM | #11 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Would most likely collect dirt pretty quickly, better to use something like graphite. I'm thinking of making that part in steel and polishing it.
08-23-2010, 11:56 PM | #12 | |
There is no binding on any of the XR10's I have seen they turn pretty smooth. | |
08-24-2010, 12:46 AM | #13 | ||
@all: thanks for the replies so far. Quote:
Sounds like the 7950th will be the minimum servo-requirement for the rig to compete with. Darn, another bottleneck. What about the S9157 users? itīs got less torque than the hitecs. donīt they overheat quite badly? Uli | ||
08-24-2010, 12:50 AM | #14 | |
I'm sure they feel smooth , but I'm talking when there is actual load on the system when it's crawling. But eh, what do I know. I have no MOA experience. I just find it odd that all of you have hot servos. | |
08-24-2010, 01:42 AM | #15 | |
Hey Uli, show us some pixs of your steering please. I think you can handle it with changing the geometrie, the original one is really bad. This mod should help a lot improving the steering: Last edited by --freeride--; 08-24-2010 at 04:18 AM. | |
08-24-2010, 03:51 AM | #16 |
Rock Stacker Join Date: Mar 2009 Location: Finland
I couldn't see that upper pic but..... Din't that mod need even more power from the servo ?? If you shorten the servo arm and make knuckle longer will help servo load ????? |
08-24-2010, 04:17 AM | #17 | |
With this mod you reduce the Ackerman: Whith the original setup the outer frontwheel -while turning- only makes a small ankle. That is what causes the problems(the servo makes a very small way). With the mod, the ankle gets much better as you see in the picture. The servo makes mor way what is reducing the load. Last edited by --freeride--; 08-24-2010 at 04:21 AM. | |
08-25-2010, 10:07 AM | #18 |
RCC Addict Join Date: Nov 2008 Location: Frederick
08-25-2010, 12:12 PM | #19 |
Hello, made a little change to my steering today: The new plate allows the servo more to travel, EPA before was 63 L/R now it is at 83 L/R, the arm of lever has now 6mm more length: that sounds not dramatically, but the 7954 stays only slightly warm and has a bit more power. Greetings Frank Last edited by Dr.Frank; 08-25-2010 at 12:15 PM. |
08-25-2010, 12:36 PM | #20 |
I think Dr. Frank's idea is killer. Better geometry for the servo = more applied torque + cooler operating temps. I see a vendor opportunity.
