05-31-2015, 12:28 AM | #1 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
| Suspension springs
Anyone come up with a good bashing set up yet? I have searched and bought the springs others have posted that worked for them. No test yet as my motor and esc will be here Tuesday. But using the search springs seem to be an issue for some and the answers I have found seem to be a band-aid for some and some are OK with the spring set ups they have found. I bought the YXL kit and am a basher and like a relatively stiff set up.
05-31-2015, 03:16 AM | #2 |
Pebble Pounder Join Date: May 2015 Location: UK
| Re: Suspension springs
I used someone elses solution from here of swapping out the front top spring for a yellow soft Baja 5B spring and putting the previous spring in the back. It's raised the front and it's certainly stiffer but I don't think it improved handling, at least on grass where I tested them, just stops it bottoming out. In turn the back now needs thicker shock oil.
05-31-2015, 09:22 AM | #3 |
Yeah I bought those to try also.
05-31-2015, 10:18 AM | #4 |
Don't forget about the springs from Axial Suspension tuning options....WoooHooooo!!. I haven't got into the suspension tuning yet but hopefully soon.
05-31-2015, 01:55 PM | #5 |
Pebble Pounder Join Date: May 2015 Location: Baton Rouge
I'm a basher, and have tried multiple combos of spring and oil wts. Like you, I perfer a stiffer set up. I tried dual rate and regular spring set ups. The best I've found is; Front: Axial Spring 23x109mm 6.76 lbs/in (Yellow) 50 wt oil Rear: Axial Spring 23x109mm 5.35 lbs/in (Green) 30 wt oil. I do have the spare tire mounted. I'm sure there is a better dual rate set up and would be interested to know also. |
05-31-2015, 05:29 PM | #6 | |
| Re: Suspension springs Quote:
Suspension springs - Similar Threads | ||||
Suspension Database Springs and Shocks | tonyfalkon | Newbie General | 3 | 05-07-2015 05:28 PM |
Help with suspension: stiffer springs needed on custom build | cragv | 1.9 Scale Rigs | 4 | 07-25-2014 03:30 PM |
suspension feels very stiff (big bore, losi white springs, 45wt oil) | GSRswapandslow | Axial AX-10 Scorpion | 15 | 04-29-2009 11:58 AM |
Suspension- No springs, Just Oil- Thoughts? | 71CutlassS | Newbie General | 16 | 07-25-2008 11:32 AM |
