Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Pro comp 2 wheels??
Old 09-15-2014, 03:49 PM   #1
Default Pro comp 2 wheels??
Are these too heavy for the yetis drive line? Will I break a lot more parts than SLWs? I bought a set of used wheels which the owner claimed were SLWs, but 2 were the pro comp. They are much heavier, will it strain the motor more?
Thanks!
Turtlejon is offline   Reply With Quote
Old 09-15-2014, 08:13 PM   #2
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Default Re: Pro comp 2 wheels??
Not a good choice for the Yeti. The rotating mass will likely cause issues.
Harley is offline   Reply With Quote
Old 09-15-2014, 08:59 PM   #3
So what would make an adequate replacement over stock if one wants to avoid the expense and weight of all metal? How do the SLWs stack up? Do they hold a bead any better than stock?
cullen colapietro is offline   Reply With Quote
Old 09-15-2014, 09:35 PM   #4
20K Club
Harley's Avatar
SLW's are all aluminum and a good choice. The KMC, Method, OMF wheels from Vanquish allow for a narrower track width and are the best choice for that reason. However they are spendy.
There are plastic options available as well. I used the Crawler Innovations 6-bolt wheels with great luck as well.
Old 09-15-2014, 11:50 PM   #5
Mr. HARLEY, will the Crawler Innovations 6-Bolt wheels work with the VP Knuckles? Thanks
YETI...Set...Go!!! is offline   Reply With Quote
Old 09-16-2014, 07:59 AM   #6
Thanks! That's what I figured...
Old 09-16-2014, 10:37 AM   #7
I'm running lurc 185 hubs with ci 6 shooters and vp knuckles with lots of room.
AWraith build is offline   Reply With Quote
Pro comp 2 wheels?? - Similar Threads
For guys running vanquish pro comp wheels on your comp trucks, please read. C_Money Tires and Wheels 18 03-24-2010 08:20 PM
