01-01-2016, 11:09 PM | #1 |
Pebble Pounder Join Date: Aug 2015 Location: Cincinnati
| Adjustable rebound and compression on Icon shocks
I want to play around with the adjustable rebound and compression pistons that come with the Axial Icon shocks and I think the directions are reversed and wrong. On the left that setup that they say slows compression is wrong. When the rod pushes up on the the piston during comp it is compression the oil above the piston and on the top cap side. Well the parts that moves to open and allow the oil to bypass around is AX80033. That piston will be forced open and allow the oil to pass quicker. During rebound the opposite happens and slam that valve shut slowing the rebound. I want to see if you guys agrees with me that the directions are incorrect. I have rebuilt a couple front forks on motorcycles and I am 99% sure I am correct. |
01-01-2016, 11:20 PM | #2 |
| Re: Adjustable rebound and compression on Icon shocks
I pretty sure that I can feel the difference, but it is so slight that it's tough to feel and from what I think I feel, I'm correct. It makes sense that it's tough to feel too because you don't want a massive difference. If you allowed the rebound to be alot faster than comp, then the shock will pump up eventually and not move in a balanced cycle. I used to road race sportbikes and learned a bunch about adjusting comp and rebound.
01-03-2016, 08:10 AM | #3 |
The instructions look right to me. With light weight oils its difficult to feel the difference but its easy to feel with the heavy oil.
Adjustable rebound and compression on Icon shocks - Similar Threads | ||||
info on the kit shocks adjustable rebound help | 8000ft | Axial Yeti | 4 | 11-02-2015 07:32 PM |
New Big Bore shocks. Question about rebound. | g_green | Axial AX-10 Scorpion | 17 | 03-13-2010 04:41 PM |
