10-27-2015, 11:49 PM | #1 |
Pebble Pounder Join Date: Mar 2013 Location: Lehi
| Pro4 3300kv and MMP - Gearing Recommendations?
Currently running the stock gearing with the 3300kv and mmp setup running 2s. After a solid 5 minute hard run the motor got pretty hot. I could hold my fingers on the motor for ~3 seconds but seemed a bit hot. Is there a recommended gearing for this setup? I realize that a Pro4 HD and RX8(gen 2) is a better setup overall but could I at least improve my situation with the current setup? Thanks in advance. |
10-28-2015, 03:47 AM | #2 |
Newbie Join Date: Jul 2014 Location: Australia
| Re: Pro4 3300kv and MMP - Gearing Recommendations?
I wouldn't expect that set up to get overly hot at all. Hot to touch may not be too hot, do you have a temp gun? Maybe there is some extra resistance in the drivetrain somewhere, how does it roll? |
10-28-2015, 06:25 AM | #3 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
Yeah I run that setup in my Wraith and never have heat issues. Wouldn't expect it to get hot in a Yeti, either. If nothing else, buy the Castle cooling fan for the motor. Should help out. But definitely check your drivetrain....sounds like something may be binding up a bit.
10-28-2015, 08:18 AM | #4 |
I did get this Yeti used and simply swapped the motor and esc in. Good thing winter is upon us which gives me time for maintenance on all 4 of my rigs Just to confirm, the stock spur and pinion and axle gears should be fine for the motor and esc setup I have? Thanks for the info, this helps a lot |
10-28-2015, 09:43 AM | #5 | |
| Re: Pro4 3300kv and MMP - Gearing Recommendations? Quote:
10-28-2015, 09:49 AM | #6 |
| Re: Pro4 3300kv and MMP - Gearing Recommendations? Not sure if there are already HD's in there already. I ripped on the yeti pretty hard the other weekend at an event and it held up really well. Granted it was more crawling than it could handle due to the open front diff but still a fun challenge.
