03-18-2015, 10:55 AM | #1 |
Rock Stacker Join Date: Nov 2014 Location: newark
| front driveshaft metal pin
I keep having a problem with my front driveshaft metal pin falling out after running my truck for just a few seconds. how do you guys keep it front falling out?
03-18-2015, 11:09 AM | #2 |
Pebble Pounder Join Date: Jul 2013 Location: Candler
| Re: front driveshaft metal pin
If you are talking about the pin that holds the drive shaft to the input on the front diff, I use Blue loctite to keep it from loosening up. It holds it just fine, I'll check it every once in a while just to ensure that it is tight.
03-18-2015, 11:11 AM | #3 |
its the little silver pin that holes the coupler to the little drum that goes inside the driveshaft
03-18-2015, 12:09 PM | #4 |
RCC Addict Join Date: May 2009 Location: Weston
Do you have the set screw installed?
03-18-2015, 12:30 PM | #5 |
I don't think one is suppose to be there according to manual
03-18-2015, 01:14 PM | #6 |
like posted above, there is a set screw that holds the pin in.
03-18-2015, 01:39 PM | #7 |
If you're talking about the center front drive shaft it has a sleeve that the joint goes in to keep it all together. Part number AX31114-1.
03-18-2015, 04:21 PM | #8 |
Where the center driveshaft connects to the front axle there is a grub Screw holding it and then the metal silver pin that goes in the driveshaft it's self
03-18-2015, 04:47 PM | #9 |
As per the manual and my last comment. Sent from my iPad using Tapatalk |
03-18-2015, 05:13 PM | #10 |
Take a picture of what your set up looks like.
03-19-2015, 02:04 AM | #11 |
R john you are right somehow I forgot the sleeve! I feel so dumb
front driveshaft metal pin - Similar Threads | ||||
busted the driveshaft pin in 3-pieces LOL | SwampDawg | Axial Wraith | 1 | 06-30-2013 04:24 PM |
Driveshaft pin alternative? | orientalgunz_00 | Axial Wraith | 20 | 03-03-2012 08:28 AM |
Stock Losi Driveshaft Pin Fix | Crawl_Before_Walking | Losi Mini-Rock Crawler | 4 | 04-08-2010 05:11 PM |
replacement ball & pin for the driveshaft on my X-Factor | 1BigJeep | XTM Crawler | 1 | 10-31-2004 09:00 AM |
