10-19-2015, 01:12 AM | #1 |
Pebble Pounder Join Date: Jun 2015 Location: Netherlands
| New Yeti
Soo, I am getting myself a Yeti kit Got most of it sorted out, but not completely sure if it is good enough to get me started. I plan on running a sensored setup: 120A sensored ESC with drag brake 3750kv 2-pole sensored motor (550 size, 65mm can) Also, I have a servo lying around from my Stampede 4x4, will that be good enough? 10.2kg/cm - 136 oz/in, 0.12 sec The rest, I'll just upgrade on the go, run it stock first |
10-19-2015, 01:15 AM | #2 |
| Re: New Yeti
You want 4 pole for the weight of the yeti and a servo with at least 300oz. Sent from my VS986 using Tapatalk |
10-19-2015, 06:32 AM | #3 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
| Re: New Yeti
Agree with the above. I have tried 540-550 size 4 pole motors in my yeti and I must say I'm very happy with my 1/8 scale motor from hobbyking. Turnigy 2350kv sensored. With a MMP. Good for up to 6s for the fast bits and still crawls great. |
10-19-2015, 07:12 AM | #4 |
| Re: New Yeti
Then i'm going to start a search for a good 4-pole sensored motor, they are pretty hard to find here in NL Sensorless, can buy everything I want, sensored barely anything if they sell sensored it's for 1:10 touring. Overseas is pretty expensive due to customs... so I try to get most in the LHS or EU stores. I guess it's this one you are using? Turnigy TrackStar 1/8th Sensored Brushless Motor 2350KV That motor has a 68mm can according to the specs, I read that 550 size motors already are a bit on the big side for the Yeti. Then how did you get that 1:8 motor to fit? Also looks like it probably will come to life on 3s minimum? This is the motor I was looking at: Turnigy TrackStar SCT 5.5T Sensored Brushless Motor 3750KV (550 size) (EU Warehouse) Combined with this ESC: https://www.hobbyking.com/hobbyking/...dproduct=52308 |
