Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Another Yeti Score build!
Old 04-17-2018, 07:59 PM   #1
Default Another Yeti Score build!
Well guys lost out on an SC10 SCT truck (going for more than I want to pay) SO made an offer on this Yeti Score RTR chassis on eBay for $215 shipped and got it! #racetruck haha
Going to make it a light weight, decent handling race truck. Typical SCT wheel/tires, body, and a few upgrades! Bought decals for a Rob MacCachren Mopar truck with another Pro-Line Ram 2500 body.
Hot Racing front sway bar
Hot Racing 43/13 gears
Traxxas turnbuckles for camber/steering
Twin Hammers rear links
Ditch the fuel cell (cut down aluminum links in place)
Axial narrow 12mm hubs
SSD servo arm
SSD Yeti D60 centered housing
Yeah Racing titanium steering link
Reedy shorty 2s lipo
Savox servo
SV3/5700kv system from my other Yeti
Traxxas black/blue 2.2/3.0 wheels
Jconcepts Dirtwebs (golds)
Few other things!
Zac_F71 is offline   Reply With Quote
Old 04-17-2018, 08:07 PM   #2
Default Re: Another Yeti Score build!
Looking forward to this one Rob Mac is one of my favourites.
BACK40 is offline   Reply With Quote
Old 04-17-2018, 08:13 PM   #3
Nice! Me too! My other truck sadly is to heavy for the SV3/5700kv SO I decided to save up and buy an 1/8 scale combo for it. So I'm donating the SV3/5700, and a few other parts from my other truck to build another ahaha
Wanted to do a light weight race style truck out of one of these to see if it could hang with the likes of race style SCT's on a clay track haha.
Old 04-17-2018, 11:33 PM   #4
I doubt it, but it'll look cooler.
Ninomaniac is offline   Reply With Quote
Old 04-18-2018, 05:29 PM   #5
That's ok I'm a crappy RC driver on a track anyway ahaha
Old 04-19-2018, 02:26 AM   #6
Even a 'lightweight' yeti will be at a disadvantage to an SCT in gearing, weight, balance, jumping, and having a solid rear axle.
If you are still set on spending your money to run a yeti against SCTs, here's my comments:
- dial out as much anti-squat as you can stand from the rear suspension.
- unlock the rear diff - I have heard that the spider gears won't last long on the track, but will will reduce 'fishtailing'
- use the stiffest blue-dot axial springs, and dampen well; you can run the suspension lower with less bottoming
- the fuel cell is integral to the chassis cage stiffness
- find out what tires work for your particular track, and get those.
DavidH is offline   Reply With Quote
Old 04-19-2018, 04:20 PM   #7
1. Noted
2. good idea! Will do that! (swap front dif for rear ahaha)
3. Noted
4. fuel cell is going to be replaced by aluminum threaded links
5. It's an indoor clay track almost blue groove - Jconcepts Dirt Webs golds are the plan
Old 04-19-2018, 05:23 PM   #8
Said F it and ordered the parts! Once the chassis shows up the modding will begin! Going to try to mount the battery further in the chassis to lower the center of gravity a bit. Very little time left to wrench sadly as it gets nicer out my 1:1 will get all of my attention here!
Parts!
Axial 7.5x80mm threaded links (making upper rear links)
Hot Racing Twin Hammers lower links
Hot Racing Yeti front sway bar
Hot Racing Wraith rear sway bar (already have)
Hot Racing 43/13 gear (already have)
SSD D60 centered plastic axle housing (already have)
SSD 25t servo horn
Protek 5x8 bearings for steering rack
Traxxas 3643 turnbuckles for camber/toe links
Traxxas 2.2/3.0 split spoke blue/black wheels
Pro-Line Ram 2500 body for a Slash
Jconcepts Dirt Webs gold compound (indoor clay)
Power HD 13kg servo
Castle 5700kv combo (already have)
Robinson 15t/18t 32p pinions (already have)
Yeah Racing titanium steering link (3x40mm)
Yeah Racing aluminum wheel nuts
Probably a few other little things I'm forgetting.. but this truck will not get much to keep it as light as possible. Will be a fun truck! - Got banned from Facebook for 7 days so pics will come when the ban is lifted (week or so, but will be waiting that long for parts ahaha)
Old 04-29-2018, 08:24 PM   #9
Big update - I decided to abandon the Traxxas Slash 2wd trans, and just put it back together. here is what I've done since this is a RTR truck -
Cut out 2 speed servo pocket
Cut out radio box
Installed 14x70mm blue extra firm front springs
(Thinking 60wt in front and 40wt in rear)
Installed machined 38/13 gears from my kit
Installed front universal axles from my kit
Installed the gear differentials from my kit and RTR
4wd restored
Installed the SSD D60 Yeti axle from my kit
56/18 gearing
Traxxas turnbuckles for camber/tie rods
Yeah Racing 3x40mm steering turnbuckles
Installed Yeti buggy rear posts in place of fuel cell
Hot Racing lower rear trailing arms
Axial 7.5x75mm rear upper links
SSD 25t servo arm
Power HD 180oz steering servo
Same Castle 5700kv from my other truck
Reedy shorty 2s 4200 lipo
Plans are changing again for this truck as well! -
Tbone Racing skid plate
Hot Racing 115mm limit straps
AE 40wt shock oil
AE 80K dif oil
AE battery foam kit
Racers Edge body foam spacer kit
New SSD rods ends
Lunsford titanium turnbuckles for tie rod, camber, rear upper links, servo link, rear sway bar links
Another Yeti Score build! - Similar Threads
Scale Yeti Score kit build Zac_F71 Axial Yeti 15 12-21-2018 11:51 AM
Yeti score build OhioSuperSport Axial Yeti 2 04-04-2018 10:06 PM
New YETI SCORE Build Malazan Axial Yeti 23 01-20-2017 03:10 PM
Yeti Score Truck to Yeti Conversion jeb. Axial Yeti 2 07-25-2016 05:58 PM
Axial Yeti Score Kit Build EDDIE THE YETI Axial Yeti 2 05-25-2016 06:56 PM
