Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Castle Creation KV Motor ?
Old 05-18-2018, 03:15 PM   #1
Question Castle Creation KV Motor ?
What castle creation motor should I get if I’m going to use it for rockracer/crawler mode with a mamba x. Is 3800 KV good for my 1/10 yeti?
What servo should I get too?
Thanks
Steelone232 is offline   Reply With Quote
Old 05-18-2018, 03:24 PM   #2
Default Re: Castle Creation KV Motor ?
Before i changed to the hh puller pro L i used the unsensored 1410 3800kv great motor and on 3 s a blast ......
magic_yeti is offline   Reply With Quote
Old 05-18-2018, 05:48 PM   #3
What specs are u using on the hobby Holmes motor that your using now?
Old 05-18-2018, 05:59 PM   #4
Should I get this one
MAMBA X SCT PRO, SENSORED, 25.2V WP ESC AND 1410-3800KV COMBO
Or just the regular mamba x esc
Old 05-18-2018, 06:31 PM   #5
it's the Puller Pro R 540-L Rock Crawler Motor with 4100kv https://holmeshobbies.com/motors/bru...motor-991.html combined with a mamba monster X, as sensor cable i use the holmes hobby monster x version.
regarding servo for your yeti, i use a savöx 1210sg. u will need at minimum 20kg of torque and full metal gears. depending on your buduget there are several options from powerhd wp 20kg, promodeller 470, holmes hobby hv500 shv500, savöx ......
Tags
kv motor, mamba x
Castle Creation KV Motor ? - Similar Threads
Castle Creation SV3 motor turn limit question arctichorse Electronics 1 04-07-2014 06:07 PM
