12-04-2008, 06:38 AM | #1 |
Quarry Creeper Join Date: Aug 2008 Location: Northern, Mi
| 2.2 Scaler wheel weights?
Ok, so im still a noob. Ive looked at 4 different sets of rules on 2 diff sites and i cant find anything. What are the rules for Scaler wheel weights? I thought i read somewhere about 12oz total weight but i cant find anything now. Yes i used the search. Thanks |
12-04-2008, 07:16 AM | #2 |
There are no rules. Use what works. BTW, you might get more views if you put this thread in one of the scale sections of this board. |
12-04-2008, 07:24 AM | #3 |
Thanks, I guess i had a brain fart, I just saw the "help" and started typing. |
12-04-2008, 07:53 AM | #4 |
Quarry Creeper Join Date: Feb 2008 Location: Bay City
Theres nothing said under 1.9 class rules. 2.4 - Class 3 Class 1.9: If a Class 3 vehicle violates any of the following requirements it must run in Class 2 or Class 1 respectively. 2.4.1 - Vehicle wheelbase is limited to a maximum of 8.5 inches. This is determined by measuring from centerline of front axle stub to centerline of rear axle stub, with all the wheels pointing straight ahead, with the vehicles suspension holding it's own weight. 2.4.2 - Vehicle track width is limited to a maximum of 8 inches. This is determined by measuring the bottom of the outer most edge of the front and rear tires while the vehicle is sitting on level ground. 2.4.3 - Vehicle is limited to 1.9 inch wheels/rims or smaller at the bead surface. Wheels may be modified provided that the tire bead surface does not exceed 1.9 inches in diameter. Tires may be modified from other sized tires using only a pliable rubber but must not exceed a total uncompressed outer diameter of 4.25 inches. 2.4.4 - Vehicles are limited to 2-wheel steering on front axle only. 2.4.5 - Vehicles are limited to the use of 2 channels radio control (one for steering & one for throttle) only. Neither channel can be used to perform more than one function. Radio systems with more than 2 channels are allowed but only 2 channels can be used to control the vehicle. 2.4.6 - Vehicles are limited to 1 ESC & 1 servo only. 2.4.7 - Vehicles are limited to 1 motor powering both of the axles. 2.4.8 No driver controlled devices, other than steering and throttle control, will be allowed. Independent throttle control to the front or rear axles (burn or dig), winching down the axles, and forced articulation are not allowed in this class. 2.4.9 A battery is limited to 8.4 nominal voltage (7 cell nimh/nicd & 2 cell lipo/limoly). 2.4.10 1.9 Crawler class bodiless overall dimension of the complete chassis must be at least 6.75" overall length, 2.5" overall width, and 3.25" overall height. 2.4.11 - If at any point during a run your vehicle falls out of these vehicle specs for any reason you will be required to take a touch penalty and correct the problem. |
12-04-2008, 08:18 AM | #5 |
I think he was looking for a "general rule of thumb" as to what wheel weight works well on 2.2 scale vehicles.
12-04-2008, 08:34 AM | #6 | |
MODERHATER Join Date: Nov 2005 Location: Colorado
Here is a quote of the rules for the Montana scale comps: Quote:
12-04-2008, 09:33 AM | #7 |
Thanks guys, I was tring to find out if it was legal to run wheels weight in the scaler class. Not how much worked well. After looking all morning I have found that all clubs are different some say No weight and some say 12oz total. Thanks 666, I knew i read it somewhere But for the life of me i couldn't find it. I just thought there was a national rule. |
12-04-2008, 09:44 AM | #8 |
