Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Duratrax Cliff Climber
Thread: Giveaway from your 2006-07-08 National Champions - TCS Crawlers - C-Trail Proto
Old 12-09-2008, 12:44 PM   #1
The Wheels Keep Turning
kevinlongisland's Avatar
Default Giveaway from your 2006-07-08 National Champions - TCS Crawlers - C-Trail Proto
TCS Crawlers
National champions three years running and Vendor of the Year!
Up for grabs is a TCS C-Trail Proto tester scale chassis
Proto tester C-TrailTM chassis for the Duratrax Cliff Climber. Side plates only. When building with this chassis you'll have to work out the link mounting and upper link mounting. We suggest for the upper that you use a long 2mm screw, the stock 2mm ID bushing that goes through the shock, and a piece of fuel tubing. This spaces the shock away from the chassis and allows it to flex. The lower links should be triangulated at the chassis. You can use spacers to do this. The upper links can be mounted directly to the chassis. The upper links can be mounted one hole outward compared to the lowers to make the camber of the axles straight if desired.
You need to have a star to enter!!!
Need a star? Here ya go: http://www.rccrawler.com/forum/payments.php
Post up ONCE for a chance to win. Giveaway ends around January 5th
TCS C-Trail
Some new and/or featured product from TCS:
New AX10 axle battery plates
TCS Crawlers AX10 Upper Link Plate (Clear) (2 each) - Only $3.99!
TCS Crawlers Axle Battery Plate for Losi Mini Crawler (1 each) $5.99
TCS Crawlers Berg Axle Plates (2) $6.99
The Crawler Store
kevinlongisland is offline   Reply With Quote
Old 12-09-2008, 01:48 PM   #2
Colt Python/SR9c
TwistedCreations's Avatar
Posting up once
TwistedCreations is offline   Reply With Quote
Old 12-09-2008, 01:49 PM   #3
oh yeah i am in.
calcat430d is offline   Reply With Quote
Old 12-09-2008, 02:02 PM   #4
I'm in, thanks
montana.matt is offline   Reply With Quote
Old 12-09-2008, 02:03 PM   #5
come on #5, thanks for the chance kevin.
Unimoger is offline   Reply With Quote
Old 12-09-2008, 02:05 PM   #6
In thanks.
hitman46mod is offline   Reply With Quote
Old 12-09-2008, 02:06 PM   #7
C-trail eh ... neat.
Thanks 4 the chance.
Nerve is offline   Reply With Quote
Old 12-09-2008, 02:07 PM   #8
Glad to see some aftermarket stuff for the cliff climber.
I'm in. Thanks.
sgil2001 is offline   Reply With Quote
Old 12-09-2008, 02:16 PM   #9
Default I am In Right On
heck yea cant wait this s great:-P
Mr Hyde is offline   Reply With Quote
Old 12-09-2008, 02:33 PM   #10
Iam in thanks
kasper is offline   Reply With Quote
Old 12-09-2008, 02:37 PM   #11
Good ol' 11 thanks
mcnastylightnin is offline   Reply With Quote
Old 12-09-2008, 03:03 PM   #12
Im In! Thanks Tcs!
BR4x4 is offline   Reply With Quote
Old 12-09-2008, 03:08 PM   #13
sweet in in.
bigflex is offline   Reply With Quote
Old 12-09-2008, 03:08 PM   #14
cartronicshn's Avatar
I am in
cartronicshn is offline   Reply With Quote
Old 12-09-2008, 03:38 PM   #15
TEAM RCC
bcrofts's Avatar
im in thanks
bcrofts is offline   Reply With Quote
Old 12-09-2008, 03:39 PM   #16
Go, go, gadget Duratraxxxxxxxxxx
Skeeno is offline   Reply With Quote
Old 12-09-2008, 03:42 PM   #17
Count me in!
gone_wheelin is offline   Reply With Quote
Old 12-09-2008, 03:49 PM   #18
i'm in
axlline is offline   Reply With Quote
Old 12-09-2008, 03:49 PM   #19
WWW.THEROXBOX.COM
Thanks, Im in
The Eye is offline   Reply With Quote
Old 12-09-2008, 03:58 PM   #20
Merry Xmas, in thanks!
genki is offline   Reply With Quote
