09-28-2009, 08:55 PM | #1 |
I joined the Band! Join Date: Aug 2009 Location: Maryville, Tn
| what is the strongest servo the stock esc can handle?
can some one tell me the strongest servo the stock esc can hold? thanks
09-29-2009, 12:51 AM | #2 |
Quarry Creeper Join Date: Sep 2009 Location: west sacramento
dont know but im bout to use my buddy's- out of his traxxis t-maxx
09-29-2009, 08:06 AM | #3 |
Newbie Join Date: Aug 2008 Location: Pharr
You can use any servo, because the servo is connected to the receiver and not to the ESC. You can use any make with ball bearings and metal gears or the titanium gears and the stronggest are the digital servos but with they draw more current from your batteries than the others. Hope this could help you. |
09-29-2009, 08:25 AM | #4 |
RCC Addict Join Date: May 2009 Location: Weston
If you use 2 servos and they are both high torque the current draw may be to much for the stock esc to handle so you might need to get and external bec.
09-29-2009, 09:57 AM | #5 | |
Newbie Join Date: Sep 2009 Location: Farmington Hills
09-29-2009, 12:06 PM | #6 |
The power for the servos comes from either the BEC in the ESC or an external BEC and is fed into the reciever. Most built in BEC's can handle 2 servos with a 2s lipo or a 6/7 sell pack. It when you start upping the voltage things get a little screwy. When you install an external BEC you disconnect the the BEC wire coming from the ESC to the reciever. The external allows more voltage/amperage to go to the servo giving you more power. I use the CC 10amp BEC to run a couple tower 995mg servos because my sidewinder would shut down on 3s lipo using the internal BEC.
09-29-2009, 02:40 PM | #7 | |
09-29-2009, 03:42 PM | #8 |
i have the rear steering locked out so will only need one servo. so i shouldnt have a problem running one strong servo....correct thanks for all the help guys |
09-29-2009, 06:49 PM | #9 |
One strong servo shouldn't be a problem at all. All you have to do is disconnect the red center wire on the ESC going to the reciever and youre good to go on the external BEC.
09-29-2009, 07:44 PM | #10 |
