03-30-2009, 10:57 AM | #1 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
| Extended link question
I've been noticing that a couple of guys on here are just lengthening the rear links and not front and rear. Is there an advantage to this other than only having to buy 2 longer shocks instead of 4?
03-30-2009, 11:19 AM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: north central IN
| That is what I had in mind when I did mine. I'm going to the local hardware in a bit to look for some small clamps to mount the stock shocks on the links so my T4 can get it's shocks back.
03-30-2009, 12:46 PM | #3 |
its about weight distribution, you always want more up front. the longer rear links moves your horizontal CG forward. is for better crawling performance. |
03-30-2009, 01:29 PM | #4 |
| Does that work as well as having them on the axle? I can get a set of 4 axial shocks pretty cheap, so don't mind buying a set and splitting them between my 2 CC's if it has any advantages. If no advantage, I will just mount to links also and save the coin.
03-30-2009, 01:31 PM | #5 |
03-30-2009, 06:24 PM | #6 |
Newbie Join Date: Mar 2009 Location: wilkes
if can't come up with the $ for the ccx chassis. i i think i'll make 1inch longer front links and 2 to 2.5 longer rears. and come up with somewat to mount the stock shocks. inless someone says thats not a good idea to do it like that. and another thing i think i need to come up with is some kinda skid plate that mounts to the bottom of the links. and will let them flex like they should.
