11-18-2007, 06:00 PM | #1 |
Rock Crawler Join Date: Dec 2006 Location: Sierra Vista
| HS-5645MG problem
Well, at our last GTG we were trying this almost impossible line, falling off every time and I managed to land on the wheel and strip out the center brass gear on the 5645. I ordered the replacement gear set and replaced the stripped gear. Went out again today for another GTG and everything seemed to work ok for a little while then it seems I lost power on the servo, everything I tried didn't help the problem, and after messing with it for a while I noticed the casing was pretty warm, not warm enough not to touch but noticeably warmer than it's ever ran before. It will hardly turn the wheels sitting on smooth concrete now. Any ideas on what's going on? Rooster Crawler Edition 45t Integy TQ2 rx/tx generic batteries |
11-18-2007, 06:05 PM | #2 |
RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
good ol` hitec servos ht servo's tend to not last(with some). i was in the same boat. just bought a tower pro 995 and it was way waaay better then the ht could even turn better |
11-18-2007, 06:13 PM | #3 |
RCC Addict Join Date: Mar 2007 Location: MS Gulf Coast
Here's my opinion on Hitec servos... That's just me, that's why I run TowerPro only now. |
11-18-2007, 06:17 PM | #4 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
You may have either bent the motor shaft or possibly bent another shaft somewhere in the geartrain in the servo. Sorry man.
11-18-2007, 06:19 PM | #5 |
Possibly you have fragments from the stripped gears in there causing it to work harder? Try cleaning it real good and then regreasing?
11-19-2007, 07:49 PM | #6 |
I wanna be Dave Join Date: Jul 2006 Location: Moscow Mills MO
My hitec 5645 and 5955 got frickin hot with the rooster crawler. So hot you couldnt hold your finger on it for more than a second. Put my MM in with a castle BEC and no superheating or loss of power. Go figure? I sold the rooster crawler but am gonna buy another in December to give it another shot. Good luck, I know I didnt help you any but just wanted you to know I had the same problem. |
12-06-2007, 08:54 AM | #7 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
I ran 5645's all season and had serious issues with the gears stripping out. I put them in my super when I built it to keep my costs down a bit, but have found that its worth dropping the extra cabbage for some nice high torque servos. Seems to be high praise for the Tower Hobbies high torques, and the Hobbico CS-170's are identical to Hi Tec 5955TG's Check out JR's new 9100T also.
12-06-2007, 09:06 AM | #8 |
the 5645MGs work well in a 2.2, but they aren't bombproof. I stick to the robot servos and haven't had an issue at all since.
01-09-2008, 09:26 PM | #9 |
Rock Stacker Join Date: Nov 2007 Location: México city
| please help me
i have a hitec 645 mg, running with a rooster crawler and i want more power, i feel the steering very weak. i have in mind to buy a hitec 5955 but im not shure because i had readed about a lot of heat issues... i have a 2.2 rig... please tell me what do you think about the hitec 5955? what kind of servo to buy , why and where? every one talk about tower pro... wich one is the srongest that fit the place of a 645mg??? Thanks a lot, i will wait a little on buying the hitec 5955 servo, first i want to know what the experts think. |
01-09-2008, 10:08 PM | #10 |
The 645mg is about the same as the tower pro in strength, and the tower pro is more inefficient. I run my 5955's in 2.2 rigs with no heat issues, but you have to make sure the steering doesn't bind and your epa's are set. If you want more power, the 5955 is the best bet and a dang good servo. I carry them because they are a great product.
01-09-2008, 10:33 PM | #11 | |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
heeeelp Please!!! hitec 5955 | |
01-09-2008, 10:41 PM | #12 | |
I dont have EPA in my radio... do you think this is a big problem?... i have the 645 and had calibrated it, not to blind the steering, i can do th same with the 5955 or no? 6,300 post!!! you most know what you are talking about! thanks a lot | |
01-09-2008, 10:43 PM | #13 | |
01-09-2008, 10:45 PM | #14 |
Post count doesn't always mean smarts, but I do a good bit of electronics testing and such on a daily basis. If your current servo doesnt bind, then you should have no problems with the 5955 either. Just drop it in. |
01-09-2008, 10:48 PM | #15 |
01-09-2008, 10:55 PM | #16 |
John... do you know how much torque the 5995 have at 7.2v ??? but in kg/cm? again thanks a lot Alan piña |
01-09-2008, 11:04 PM | #17 |
Eerrrrrr, I have never been able to do that conversion proper. It is a lot, probably 20kg/cm or so.
01-09-2008, 11:28 PM | #18 |
01-09-2008, 11:57 PM | #19 | |
Stall Torque: 24.0kg.cm (333.29oz.in) at 6.0V / 30.0kg.cm (416.61oz.in) at 7.4V Last edited by yotachump; 01-10-2008 at 12:00 AM. | |
01-10-2008, 12:24 AM | #20 | |
RCC Addict Join Date: Jan 2004 Location: Gunbarrel
http://www.linengineering.com/flash/Calculator.swf | |
