12-21-2008, 05:31 PM | #1 |
Newbie Join Date: Dec 2008 Location: Stafford, Va
| glitching prob after esc switch
I running futaba 2pm radio and I had the tazor15 esc to a integy matrix 55t v10 motor with no glitching. I just switched to a rooster crawler and its glitching hard. From what I read the matrix allready has caps, but everthing points to adding 3 external. Help a noob out please.
12-21-2008, 05:53 PM | #2 |
RCC Addict Join Date: Dec 2005 Location: Tucson
Thats novak for you.
12-21-2008, 07:13 PM | #3 |
Quarry Creeper Join Date: Aug 2008 Location: in the basement cussing my broke ass rig
Does the matrix have a small circuit board with surface mount caps? If you somehow burned them up, you will need to replace them. Unless you have above average soldering skills, changing surface mount can prove to be a pain in yer arse. You might try replacing them with regularly mounted mica caps.
12-24-2008, 06:21 AM | #4 |
They do not apear to be burnt, so I put the tazor back in no glitch. Putthe rooster in again still glitching. Might just be this shitty am radio.
12-24-2008, 06:37 AM | #5 |
Undo to the screw on the circut board and it will slide out. Solder the 3 included caps that came with the rooster. That should do it. You can't tell when you burn up the surface mounted caps. It just starts glitching. Mine did the same thing and trying a Tazer 15T ESC it didn't glitch... That's what made it so confusing and difficult to figure out what was wrong |
