01-09-2009, 02:14 PM | #1 |
Quarry Creeper Join Date: Jan 2007 Location: HAY CAPITOL OF THE WORLD!!!!! weeeeeeeeee
| charging aaa packs
I know the superbrain 959 says it does aa to sc batteries but if i plug in a 7 cell AAA Pack would it be okay if I charger them @ like .05 amps? They are 650MAH NI-MH packs BTW
01-09-2009, 04:30 PM | #2 |
I'm not sure why they specify a battery size limit. You should be able to charge those at .5 amps with no problems.
01-09-2009, 04:44 PM | #3 |
I charge AAA cells on my Hyperion all the time. I set it to .5 amps and hit the go button. As long as you can select the charge rate,it should work fine I'd think.
01-09-2009, 05:03 PM | #4 |
Newbie Join Date: Jun 2008 Location: Flagstaff
when i had rechargeable aaa batteries, i charged them at 3A they got super hot, but they worked great for about half a year. and they took a while to cool
01-09-2009, 05:16 PM | #5 | |
I've seen AA cells vent charging at 1.5 amps. | |
01-09-2009, 05:18 PM | #6 |
Heat is a killer for batteries. Depending on how much capacity they had, at 3 amps, you were probably charging them at a rate that was at least double what would be the ideal charge rate. For example, if the batteries were 1500mah, then you charge them at 1.5A to get the most cycles out of the cells. For Dubs' batteries, a charge rate up to .65A would be safe to get the most cycles out of the batteries. I use cheapo Ray-o-Vac rechargeables and I've had to do some "emergency" charging before a comp or two and hammered them with around 2.5A and it pretty much was the death knell for 'em. The cheapy Wal-Mart batteries cannot take much punishment. |
01-09-2009, 09:40 PM | #7 |
Thanks guys I appreciate it.
01-10-2009, 02:56 AM | #8 |
Rock Stacker Join Date: Oct 2005 Location: stockton
I'm running 7cell AA Duracell's 2560mah and charge em' at 1A only with a few emergency charges here and there @3A. It gets a little bit warm but I always set the batt right next to the charger fan so that helps out a lot. I've had the cells for over 3yrs now and it's still holding charge capacity. I guess it all comes down to the quality of the cells and the user on determining the battery life expectancy.
