Tekin FXR Freak-Out! Hello Everyone, First post here guys so be kind "thumbsup". I have just got into RC rock crawling from the 1:1 variety and have built an AX-10. Here are the Specs... - AX-10 Kit - Tekin 45T combo with FXR - Front XP Digital DS1015 Servo - Rear Spektrum Z590 Servo - 2S Lipo (Losi Rx Pack) - Spektrum DX3.0 (currently being exchanged for DX6i) - SR3000 Rx I love the thing and it works great but I am having a shutdown issue with the FXR. If I go hard forward to hard reverse all of the electronics shutdown. No automatic restart... I have to unplug the battery and plug it back in to get them back (reboot!), then the truck works fine until it happens again. The shut down issue also happens when the truck is under load (i.e. bound-up in the rocks). I have disconnected the servos, thinking that there was too much draw on the FXR BEC with the XP servo, but it still happens when going from hard forward to reverse and no servos connected to the rx. The other wierd thing is that, as I am now returning my DX3.0, I have a basic 2 ch. 27MHz axial radio and rx in the truck until I get back the DX6i... With this set-up, there is lots of glitching (both channels, cheap radio + I live in the city) that will actually cause the FXR to shut down when the truck isn't even moving (much worse than with the DX3.0).It just basically twitches around (drivable) until it dies. Any ideas on what's going on? Is it possible that just the 45T Tekin motor can trip the internal BEC alone when going hard forward to reverse (i.e. with servos disconnected)? I have checked the soldering joints and wires... All seems OK. The temp LED's on the FXR never get higer than 2. Thanks for your help everyone, great board... Mike |
What size is the battery? If the battery is really small or has a low C rating, it may not take that much amp draw. |
The DS1015 can pull a lot of power. Running 2 servos on the FXR BEC is most likely the problem. I would definitely recommend an external BEC like the CCBEC. http://www.tcscrawlers.com/Castle-Cr...r-p-16518.html |
cc bec"thumbsup" |
The battery is 2000mah (2s lipo). I agree that the servo(s) could draw enought to kill the BEC in the FXR. However, even with the servos disconnected from the rx, I can make the FXR die by going hard forward to reverse. What I am trying to figure out is whether this is normal for the FXR? I can see the need for a CCBEC (with servos), but if the FXR is shorting with no servos connected, is there something else wrong? |
When the truck shuts down do any of the LED's flash? Quote:
This losi rx pack???:shock::shock: http://www.losi.com/Products/Feature...rodId=LOSB9820 |
Is it the FXR cutting out, or the reciever cutting out. On my sc10(not a crawler i know) the tekin r1pro would not have enough power and shut down the Rx. CC Bec fixed everything. |
Good Morning Guys, Yes that is the lipo pack I have and was told that there were a bunch of guys using them successfully in their crawlers... Is there an issue with it not being able to feed enough current? When the FXR dies, everything shuts down. No LED's, totally dead. Turning the switch off then on does nothing. I have to unplug/plug the battery in order to bring everything back to life. Thanks again |
For a single motor crawler you should run at least 20C if not more. Opinions vary but you will rarely see anything used below the 15C range and I see many people using 35C batteries. "thumbsup" |
I told the guy at my LHS that I couldn't believe that enough current could be fed through those wires! I need a new LHS :-(. Will I still need the CCBEC? |
Try it without a bec first, just check the esc temps to make sure it isn't getting close to overheating. I always run a bec on all my stuff so the esc doesn't have to do that extra work. |
Agreed, that a$$ also sold me that DX3.0 knowing that I was setting up rear steer and it only has a 2 pos switch for the AUX channel... Irritating... Thanks again for all your help guys, going over there now to 'deal with this issue'. |
I'm always for "trying" to use a local hobbyshop, but when the sales person is more worried about making a "sale" than taking care of the customer, it just, well, I can't say the words online... If you decide to buy online, Holmes Hobbies has a good deal on lipos that can handle the load! |
