11-15-2005, 03:10 PM | #1 |
Newbie Join Date: Feb 2005 Location: PA
| Need a Schematic
What I have is : Two lathes Two novac super duty ESC One 4 channel reciever (airplane) I can run one or two batts whatever works, I do not know how to run two esc's and one batt. Thanks Ross |
11-15-2005, 03:12 PM | #2 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
to hook up the battery tie the 2 +'s together and the 2 -'s together and hook them to a single battery pack.
11-15-2005, 03:49 PM | #3 |
do I need to rin a reciever battery? Thanks Ross |
11-16-2005, 09:07 AM | #4 |
Pebble Pounder Join Date: Apr 2005 Location: England
depends ont he servo and the amp draw - just remember to disconnect the bec from one of the ESC's
11-16-2005, 01:55 PM | #5 | |
What do I need to disconnest? The bec?? What is that? Thanks Ross | |
11-16-2005, 04:10 PM | #6 |
Rock Crawler Join Date: May 2005 Location: omaha
On my esc it is the red wire that plugs into the reciever. You also might want to be careful running a air radio for a truck. I think that is a no no.
11-16-2005, 04:41 PM | #7 | |
The raido will be a surface freq by christmas with the v6000 on the way What does the bec do and why would i have to disconnect one and not both, should i just run one for each servo: two esc two motoe twoservo??? Thanks Ross | |
11-16-2005, 04:53 PM | #8 |
Cool about the radio. If you were to hook up both esc's with both bec's, you would be feeding 12V into your reciever. All you would see is the magic smoke, and that would suck. |
11-16-2005, 05:10 PM | #9 |
Rock Crawler Join Date: Aug 2004 Location: woods cross utah
6v+6v in parallel is still 6v.
11-16-2005, 05:18 PM | #10 |
Really? Why is it that I had to unhook the bec wire from my esc when I hooked up my reciever pack? Sorry, not trying to hijack your thread. |
11-16-2005, 07:45 PM | #11 | |
No, please explain..... I am learning about this as well. Thanks Ross | |
12-11-2005, 05:46 PM | #12 |
I finally have this together and I have a few more ???? i wired the ESC's off 1 bat. I wired the servo's eith extentions. everything is together. I cannot seem to get the esc's to prog. settings? I am running a OLD OLD airtronics Vanguard 4 channel radio and an old airtronics 7 channel reciever. This thing is killing me. The servo's will not even turn. Is my reciever bad??/ Any help would be apperciated. |
12-14-2005, 09:51 AM | #13 |
I joined the Band! Join Date: Aug 2005 Location: Cincinnati
to program the ESC's program them one at a time unhook one program it then hook the other up and unhook the first and program it. check that the tires run the proper direction and if not reverse the programming.... it takes about 3 or 4 tries at the hookups to get it proper. I assume its a clod! |
