11-08-2009, 07:52 PM | #1 |
| 11.1, 27t motor, 18t pinion... bad idea?
I am getting tremendous wheelspeed with this combo in my ax10 based racer. Is this a good setup that will last? I'm running the stock axial rtr motor. the battery is a 11.1v 10c 1250 |
11-08-2009, 08:10 PM | #2 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
thats a large amount of amps to be pulling from that pack. that pack is only able to supply 12.5 amps continuous, id bet a 27 turn in a crawler will run at almost double what that pack can supply. i myself would run something much bigger, such as an 1800 30c or more.
11-08-2009, 08:55 PM | #3 |
Thanks for the reply sharkey. I have a novak 55t on hand. I suppose that would suit the life of my pack better? |
11-08-2009, 09:14 PM | #4 | |
I ran a puller in my Axial with 18/81 gearing,which probably pulls even more than your 27t stock can. I always ran a PolyRc 25c 3 cell lipo from Holmes. Worked extremely well and never had the first issue with the battery. | |
11-09-2009, 07:18 AM | #5 |
Thanks Reflection! Is there a chart or way to calculate if your batteries C rating isn't enough for your motor? Originally I have been running a 7.4 2000mAh 20c on the 27t motor w/18t pinion. |
11-09-2009, 07:46 AM | #6 | |
You might browse through the stickies in this section. I know there's enough info on batteries and motors in them to make your eyes bleed if you weanna read it all. | |
11-09-2009, 07:55 AM | #7 |
