11-23-2009, 09:01 PM | #1 |
Rock Stacker Join Date: Feb 2006 Location: Sugarland, TX
| 35 turn and water!
i have an scx10 with this motor, everytime i drive through water deep enough to reach the motor the sand and grit get in and stop it from running. I have to blow it out with electrical cleaner and sometimes that doesnt work. i took the motor apart and cleaned it and now works great! i thought about getting a outerwear but dont know if that will help. does anbody else have this problem? and if so what did you do to fix it? thanks
11-25-2009, 10:24 PM | #2 |
Nobody has had this problem? or should i ask the scale guys?
11-26-2009, 05:03 AM | #3 |
Yeah....if sands gets in the motor it will stop. It is this way with most motors that have cooling holes in the can
11-26-2009, 12:18 PM | #4 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
I feel your pain not much you can do except wrap the motor with some foam like they use for air filters on gas engines. It will help extend the life of the motor for a while. Last edited by hitman46mod; 11-26-2009 at 12:33 PM. |
11-26-2009, 06:59 PM | #5 |
Quarry Creeper Join Date: Jun 2009 Location: Way down under!!!
I used to chuck an old fashioned party balloon over my motor, worked a treat.
11-26-2009, 07:04 PM | #6 |
Rock Crawler Join Date: Aug 2007 Location: Orlando
In our club we by sweat pants and cut the material and wrap it around the motor, tiny holes for the motor to breath yet small enough so crap doesn't clog the motor. Clean it every other run and your golden. |
11-26-2009, 07:56 PM | #7 |
sounds good! i will try the sweat pant idea. thanks.
11-26-2009, 09:09 PM | #8 |
Quarry Creeper Join Date: Apr 2009 Location: Indianapolis Indiana
can you use t shirts or any other material?
11-26-2009, 09:23 PM | #9 |
11-26-2009, 09:31 PM | #10 |
get a knock off under aumor shirt and wrap it
11-26-2009, 09:48 PM | #11 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
your wifes / g/fs or moms /sister panty hoes
