12-15-2009, 08:46 PM | #1 |
Quarry Creeper Join Date: Oct 2005 Location: Lebanon
| Hitec 7950th Question
hitec 7950, says it is designed to work with a 2 cell lipo pack, can it work with a 3s? Like if you had a bec or something?
12-15-2009, 09:19 PM | #2 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
it would work fine with a bec on 3s. the servo is designed to work off 6v or 7.4 volt, it gets best performance when you supply power to it direct off a 2s battery. with 3s i would run a bec set at 7.4 volts just to power the servo and use the speed controllers internal bec to power the receiver. in a 2s system you dont need a bec, just run power direct from the battery and use the esc internal bec to power the receiver.
12-15-2009, 09:34 PM | #3 |
I wanna be Dave Join Date: Jun 2006 Location: Ukiah
We got smokin deals on these right now too Awesome servo!
12-15-2009, 10:11 PM | #4 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
One thing a lot of guys don't realize is that you can program these servos for a wider than standard throw angle. This can help you get as much steering as possible when faced with certain link set-ups that force you to use a short servo arm. Narly1 |
12-15-2009, 10:14 PM | #5 | |
12-15-2009, 11:10 PM | #6 |
yes it can, you just need to program it with the castle link.
12-16-2009, 02:29 AM | #7 |
12-16-2009, 10:15 AM | #8 |
Quarry Creeper Join Date: Oct 2007 Location: Toronto, ON. Canada
im running my 7950 through a bec @ 7.4V, powered off a 3cell like said, if you have a 2 cell just run some servo pigtails connected off the battery connector. |
12-16-2009, 10:17 AM | #9 | |
I run mine at 6v simply because they are plenty strong at 403oz, the servo runs cooler, and will last longer than at higher voltages. | |
12-16-2009, 12:47 PM | #10 |
In your original question you asked if it could take a 3S. When Hitec says that it can run off of a 2S lipo....they simply mean that it can handle an input voltage of 7.4V. However you wish to supply that voltage is up to you.
12-16-2009, 12:52 PM | #11 |
Quarry Creeper Join Date: Sep 2007 Location: Central Coast, NSW, Australia
If it can run straight off a 2s battery, the peak voltage of that is more that 7.4v. Something over 8v at full charge. Shouldn't you be able to crank your CCBEC up to 8-odd volts and the servo happily run on that? After all, the 7955 runs on 7.2v happily all day, and that's not even classed as 'high voltage'. Last edited by LincolnBlack; 12-16-2009 at 12:54 PM. Reason: Spellcheck |
12-16-2009, 02:23 PM | #12 |
I wanna be Dave Join Date: Dec 2008 Location: ?
