01-17-2010, 04:12 PM | #1 |
Rock Stacker Join Date: Dec 2009 Location: Etowah
| Help! Help! Esc
Ok I am getting extremely frustrated! I added a DNA dig to my ax10, also upgraded to a DX 3.0 radio. Now I cant get my truck to run at all. The DIG works fine but when I turn the truck on it gives the series of beeps pull back on the throttle one time and then the truck just sits there and beeps. beep beep beep but no forward or reverse. I have a castle sidewinder esc, DX 3.0 radio , brushless motor. The truck ran fine before starting the upgrades and I have been fighting this deal for saveral days now. I desperatly need help from all you experts out there and keep in mind I'm already in trouble with the wife about all the money I've been putting in the upgrades so someone out there knows how to fix this thing PLEASE help ASAP. Thanks |
01-17-2010, 04:22 PM | #2 |
Do you have the Castle Link or are you setting it up via the tx? edit: usually when it beeps like that it isn't getting a signal from the rx. You're sure you've gotten everything plugged in right? |
01-17-2010, 04:34 PM | #3 |
| plugs
I'm pretty sure I have it all plugged right looks like I have a open space at the bottom of the reciever then the next slot is steering servo, next esc next dig. Sound right?
01-17-2010, 04:45 PM | #4 |
Does your steering work? If so, swap the esc plug with the steering plug and see if it'll do anything then.
01-17-2010, 06:16 PM | #5 |
Pebble Pounder Join Date: Dec 2009 Location: Who Dat Louisiana
Since you changed radios, you will need to redo the setup on the sidewinder.
01-17-2010, 08:57 PM | #6 |
I can try swapping the plugs in the morning, the steering and the dig work it just wont go. I can't figure out how to reprogram, I didn't have any problem programming it when I had just the cheap 2 channel radio it came right up but don't seem to want to program now, or more than likely I don't know what I am doing.:-(
01-17-2010, 09:03 PM | #7 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
OK, here is what you do. 1. Unplug everything from the Receiver. Your wiring should look like this. (Continue to read after picture) 2. be sure that you first complete the bind process first 3. After that is finished complete the set up of your ESC settings. 4. Remove the red wire and follow the picture. 5. Run the truck. 6. If you still have issues, Be sure to set all your settings on your radio to (0) Generally this is what most of the time is the issue. Its because your radio wasn't programmed at 0 settings to dial in everything. So the radio program isnt recognized by the ESC Last edited by team3six; 01-17-2010 at 09:05 PM. |
01-17-2010, 09:06 PM | #8 |
| picture
ok I cant get that picture to come up is the another way you can get it to me
01-17-2010, 09:07 PM | #9 |
what are you talking about you cant get it to come up? Just go to this link. you must have some issues with your computer if you cant see that. http://i265.photobucket.com/albums/i...cs/WIRING2.jpg |
01-17-2010, 09:11 PM | #10 |
| got it
Ok got it that time I'll give it a try, when you say set all to zero on my controller you mean ALL correct.
01-17-2010, 09:19 PM | #11 |
Set all your settings on your radio to 0. Its been awhile since i had a 3.0 so I cant remember how. But all your travel, steering, throttle. everything to factory settings |
01-17-2010, 09:27 PM | #12 |
Ok thanks I'll give it a try when I get off work in the morning thanks.
01-17-2010, 10:18 PM | #13 |
Pebble Pounder Join Date: Apr 2009 Location: Gresham
If your not running a BEC then leave the red wire hooked up. If your steering and dig servos are working, then your controller must be bound so I would be looking at settings. Like team3six said, zero everything out on the controller and start there. I don't know anything about the radio, but maybe the throttle limits are messed up. I just upgraded from a modded tq3 to a 3pmx and had to play with it for a while to get things right. The factory settings were all over the place. I'm sure nothing changed but it wouldn't hurt to use the castle link and verify the esc settings. When you turn it on, the esc should beep a few times and then give you a tone. Turn the radio on first and then the esc and let it just sit there for a few seconds without touching anything on the radio.
01-17-2010, 11:12 PM | #14 |
Ok I'll try that first, when I turn everything on it does give me that normal crazy beep, but then thats it of coarse I haven't let it set for a few minutes. Also It only gives me one of the beep cycles where as the old radio used to give me two. One when I turned it on and then I would pull full throttle one time and it would give me the second set of beeps and after returning to nuetral position you were ready to go, now I don't get the second beep. Like you say I may not be giving it enough time.
01-18-2010, 09:40 AM | #15 |
It shouldn't take longer than a few seconds though really! Mine beeps 3 times and then gives me the musical tone. I never touch the radio when turning it all on.
01-18-2010, 11:48 PM | #16 |
| Gettin closer
OK guys thanks for all the help I'm getting closer. I finally got the wheels turning. I think most of my problems right now are in the radio settings, once I finally got it going it is running in reverse and I can only steer in one direction now, the dig servo don't have as much travel as what I had before. Most likely from where I zeroed out the radio to get the esc to program. So tommorrow I will start going through and see if I can get all the settings right on the radio, not much experiance with this but I have the book so maybe I can get it figured out.
01-19-2010, 02:10 AM | #17 |
Keep us posted. Hopefully its just a matter of dialing in the radio. It sounds like thats all it is.
