08-01-2010, 12:38 PM | #1 |
Newbie Join Date: Apr 2010 Location: canada
| 20c or 30c
what would u guys recommend the 20c or 30c 2s 5000 mah lipo battery for my axial scx10, with stock 27t motor? |
08-01-2010, 12:42 PM | #2 |
Rock Crawler Join Date: Jul 2009 Location: boise
a 30c would be more power, it has more output than 20c so it would die faster though.
08-01-2010, 01:00 PM | #3 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
30C can handle more of a draw than a 20C, but in a crawler, you will likely notice no difference at that capacity
08-01-2010, 03:04 PM | #4 | |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
20c or 30c, not going to matter much in a scaler. a 5000mah 20c is good for 100 amps, a 30c is 150 amps, nowhere near what a scaler will pull. imo, buy the cheaper one, save cash for other upgrades | |
08-02-2010, 10:25 AM | #5 | |
the difference in price between the 20c and 30c is 3$ lol. not bad | |
08-02-2010, 11:33 AM | #6 |
in that case buy the 30c then. ya never know what r/c you might end up with down the road and if you end up needing some good lipos, you have them.
08-02-2010, 11:44 AM | #7 | |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
The higher C rating, the more efficient the pack. You'll likely get slightly higher wheelspeeds with a higher c pack. Not only do you have more amperage with a higher c pack, you have higher available voltage at the same amp draw. Example, say you have a 20c and a 30c pack. At 50 amps, the 20c pack will have a lower voltage than a 30c pack. Last edited by jcboof; 08-02-2010 at 11:55 AM. | |
08-02-2010, 12:00 PM | #8 |
The 30c will also take a bit faster of charge. If it is only $3, get the better battery. Higher discharge rate batteries will take more abuse and live longer.
08-03-2010, 10:49 AM | #9 | |
But if there is only a 3 buck difference, go with the 30C. You might have a brushless go-faster some day that would like that pack. | |
08-03-2010, 11:20 AM | #10 |
Chris, I agree with you on this on the fact that with the size of the lipo he likely would not notice much difference. But with a powerful brushless motor, he would likely notice it. I noticed a HUGE difference in my VTA car when I switched from a 20c to a 40c 5000mah pack. In a smaller pack like most comp crawlers run, you would definitely notice a higher c pack. Put an 850mah 15c pack in my truck, then put in my 850mah 90c TP pack and you'll crap your pants. Its that big of a difference. |
08-03-2010, 11:30 AM | #11 | |
08-03-2010, 02:28 PM | #12 | |
Rock Stacker Join Date: Aug 2009 Location: Hawaii
