02-14-2011, 07:03 PM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: Joliet
| lookingb for a new esc
Hi guys once again I need your help. I'm looking for a good esc with break and preferably waterproof. I'm running a 27T axial brushed motor and I use a 6 cell 2400mah nicd battery pack. What esc would you recomend that's easy to use and hook up and one that you guys have had good experience with? And also wats a turbo bec and would I need one? Thanks in advance |
02-14-2011, 10:53 PM | #2 | |
Quarry Creeper Join Date: May 2009 Location: Under Communist Occupation
An option - sorta, would be to by a Traxxas blue XL-5 WP esc, and use a HPI gear reduction unit - if slowing it down is not a problem. | |
02-14-2011, 11:18 PM | #3 |
Pebble Pounder Join Date: May 2009 Location: farmington crawler capitol
Just say no to Novak I would recommend Tekin rs line very reliable ESC
02-14-2011, 11:24 PM | #4 |
Newbie Join Date: Jan 2011 Location: NW Suburbs
| Although the tekin rs esc is one of the best out there, I think its a little overkill for the application. Am esc that functions nearly as well for that application could be had for a third the cost.
02-14-2011, 11:30 PM | #5 |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
What are you putting in?
02-15-2011, 12:13 AM | #6 |
Pebble Pounder Join Date: Jan 2011 Location: Mtz
I'm guessing this is going in an ax-10? If u plan on sticking with brushless, you could always look at the Holmes hobbies br-xl. I just got one and replaced a waterproof xl-5, wow was it an upgrade. It is programable with a castle link, has a built in bec, and can handle up to 6s lipo. You can program throttle curves and adjust the drag brake on it. For crawling the xl-5 sucks, you have to double tap for reverse and has no brake except for the first tap into reverse. You can order one from www.holmeshobbies.com and get it waterproofed.
02-15-2011, 12:17 AM | #7 | |
Tags |
axial, esc, scale, scx10, waterproof |
