Thread: Battery Problem?!?
Old 02-14-2011, 03:11 PM   #1
Exclamation Battery Problem?!?
Ok first of all i have a XR10 i have (2) 800 mah lipo batterys it wont let me charge, discharge, or balance the batterys. The reading says one of the cells is way lower than the other.
When i go to plug in the battery to the XR the steering works great but when i hit the throttle it kinda winds and jerks a littlebit forward and then backwards when i put it in reverse?
Is that the battery or maybe the radio off tune?!?-Spektrum DX3R
If anyone has had this problem let me know thanks!!
newmexico is offline   Reply With Quote
Old 02-14-2011, 04:54 PM   #2
Does your charger have the capability to balance?
day215 is offline   Reply With Quote
Old 02-14-2011, 06:48 PM   #3
if your voltage is way low becarful with that battery i would use my blinky on it try to level them off
CPT.HOOK is offline   Reply With Quote
Old 02-14-2011, 09:15 PM   #4
Default yea i do
yes it does it seemed like it almost balanced when it shut off on me 2 cells were at like 3. something and the other was like 1. something so tryed to ballance and it didnt let it finish ballancing
