Thread: x2 mamba micro pro cc link setup
Old 03-08-2011, 12:06 PM   #1
Default x2 mamba micro pro cc link setup
Here's my frist set up for my Mamba micro pro X2 F/R (pic below) right now running 55t novak motors,novak "The Dig", Dx3-e. With this set up if going full throttle forward and just let go of Throttle trigger rig will flip over on a down hill. I could ease out of trottle no problem. So maybe some one could post up their set up profile.
By tappedout at 2011-03-08
tapped-out is offline   Reply With Quote
Old 03-08-2011, 01:29 PM   #2
to help with it flipping over dial back the drag brake little bit till you get it where you want. with the lipo cutoff i would bump it up to around 3.2-3.3v to give some leeway, and the brake amount can be set to zero since it isnt even used
benoj is offline   Reply With Quote
Old 03-08-2011, 04:46 PM   #3
Thanks thats what I was thinking as of now brake turned down to 0 F/R. dragbrake Front 190% rear 213%. Bumped lipo cutoff up to 3.2v .
testing in the house with front dragbrake turned down to190% seem to keep rear wheel on the ground. Full speed to sudden stop
