Thread: futaba servo case?
Old 05-03-2011, 05:40 PM   #1
Default futaba servo case?
so i broke the mounting ears off of my s9351 servo in a hard HARD roll over. as a temp fix i put my old hitec 645mg in. which really sucks in my honcho. while i was swapping them i set the futaba next to my traxxas 2070 that i tried as a winch. the cases look almost identical other then the sticker and the futaba has the alumuinum heat sink case. does anyone know if they will swap. just for a short time fix.
edit. the futaba case set alone is $43 on towerhobbies http://www3.towerhobbies.com/cgi-bin...?&I=LXHUN6&P=Z
toka100 is offline   Reply With Quote
Old 05-03-2011, 06:05 PM   #2
Suck it up!
Duuuuuuuude's Avatar
Try it.
Duuuuuuuude is offline   Reply With Quote
