Thread: servo confusion.....programming/wiring
Old 05-04-2011, 01:08 AM   #1
Default servo confusion.....programming/wiring
First heres my setup. Servo yellow wire to channel 1 black and red to cc bec so servo gets the ccbec to itself. Novac bec powers receive. There is no esc connected. This setup worked previous to today. I got a Hitec hfp-20 servo programmer to adjust endpoints on my 7955 hi torque servo. After adjusting endpoints i hooked everything back up and nothing. The servo doesnt work at all. I unhooked the novak bec and put the cc bec in the receiver and hooked servo straight to channell 1 then it works. so then i changed out the rx and transmitter with known good units and same result. What's going on here? I did check the cc bec and novac bec with a multimeter and got correct results 6v for the novak and 7.4 for the cc bec(which is where i set it)
PowerCrazy is offline   Reply With Quote
Old 05-04-2011, 11:14 PM   #2
any ideas? This is driving me crazy
Old 05-08-2011, 03:06 AM   #3
Maybe a ground issue?
Old 05-08-2011, 03:43 AM   #4
try a ground wire from the servo to receiver. cant think of anything else as i dont know the servo programmer. maybe it something you are doing with that.. could be wrong tho.
M1tch is offline   Reply With Quote
