Thread: starter box motor 550 size?
Old 06-20-2011, 04:47 PM   #1
Default starter box motor 550 size?
does anyone know what starter boxes use a 550 motor? I got a used one from the local hobby shop and I want a backup one there is no markings except says pro by the wire leads. any help please I'm running it in a lcc and wow wheel speed
thomass14 is offline   Reply With Quote
Old 06-20-2011, 06:43 PM   #2
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Can you take a pic and some reference measurements of the motor? Any other markings?
JohnRobHolmes is offline   Reply With Quote
Old 06-20-2011, 07:22 PM   #3
I can measure tonite when I get off work and will post in the morning but its the same size as the titan 21t. there was some numbers on the heat shield i'll write them down. thanks for trying to help
Old 06-21-2011, 07:20 AM   #4
ok on the heat shield the # 55157156 the first number is only half there so guessing on 5. can width is 36.65mm length 56.89mm pinion shaft is 3.17mm width and length thru can is 74mm and is round no flat spot for set screw. If i remember rite there was a pinion on the shaft that i had to heat and pry off. I tried to take a pic but my phone sucks wasn't clear at all sorry. On the back of can positive is on the left, has pro stamped on top and bottom there looks like a circle with two half circles on top of the other circle looks like a lady bug stamped in metal haha sorry best way i can explain the pic couldn't show this hope this helps I will try and get a camera and take good pic thanks for your help
