Tx programming Note: I am pretty new to radio programming, as I usually stick with the stockers. I recently picked up a dx3c but can't get the throttle epa low enough, can only hold in nuetral position by applying brake. This must be common tx knowledge; some method I'm not trying? Sub-trim is for servo only, correct? Thanks |
Have you tried programming the esc to the radio? That should take care of it. |
There should be trim and subtrim for the throttle too. Like post above, zero trims, set end points to 100 and calibrate esc. |
Well I got it worked out via throttle trim settings. It is a non-calibrating esc; I think an fxr is in order soon. Thanks for the replies |
EDIT: I tried to find some info on it and cant? http://www.axialracing.com/ftp/pdfs/...1_AE-1_ESC.pdf |
IIRC, with the radio on, you hold the throttle down, turn on the truck, wait for a beep, move the trigger to full brake, wait for a beep, then go to neutral (let go of the trigger). There will then be a sequence of beeps and you're done. I may have the reverse to neutral part backwards. Its been a while. To be safe, keep the wheels off of the ground, or remove them entirely and let the rig sit on the axles. |
My esc is a lansu (redcat)-one of the 2 things that remain redcat. |
