ae1 reverse is slow! So i'm running the ae1 esc and a 55t motor, and it seems as if reverse is dying. the more I use reverse the slower it gets in reverse. Forward speed is same as it has been. I have pulled the motor and checked the brushes and wires, everything seems to be fine. I'm thinking it might be the esc its self. what do you guys think? |
Have you looked at TX settings? It's possible a setting (EPA?) is getting moved. Did you check to see if the motor endbell is moving (changing timing)? |
