Glitching HITEC 7950Th set-up Mamba Max Pro set with internal bec at 7.0v also tried 6.0v in a scaler. MMP is set for brushed motor w/ reverse. I have tried 3 RXs thinking that was the deal. The Hitec 7950TH is brand new but I have come to the conclusion that it is the issue. When the rig is turned on and you throttle everything is now fine, but steering all you do is get alot of twitching. Do I just need to run a external castle bec for the 7950th to work properly?? |
I'll point my finger at the radio since you didnt mention what radio your using. With the servo under load the stock internal bec on the MMP will shut off but it should still work for bench testing. |
I believe the CC BEC will fix your issue. When you hit the steering, it drops the RX voltage which causes the glitching. Running a CC BEC direct to the servo should fix this. |
Ya I'm thinking the bec too. I will hook one up after work. The radio is a Dx3r. It's just weird b/c I never had a problem that I can remember like this with any 5995 or 7995s. |
I had the same exact problem and the cc bec fixed it right away |
interesting... i had the same problem, had the BEC installed and it was still doing the same thing. So i cut the voltage back to stock on the servo and it's been all good. I just stay away from turning the voltage up. |
MMP's BEC is only three amps, 7950 can pull 10 or so. I've had good luck running 5645's on MMP's but 7950's were a no go. Turn the voltage to 8.4 on a CC BEC and you'll be fine. concretejungle, I've had an issue with MMP/7950/CC BEC/Losi 2.4 Rx where it glitched unless the signal and ground were plugged into the Rx, signal only like I've done in other setups glitched. But I've never saw an issue due to voltage, 8.4 volts is stock, it's designed to run direct off 2s lipo. |
Never know... could be running DSM1 that really doesnt like to be over 6 volts. Just a thought "thumbsup" Either or the OP should be posting up all his info and not half of it to get a whole answer |
