Thread: 3racing winch spool in only one direction?
Old 06-27-2011, 08:30 AM   #1
Default 3racing winch spool in only one direction?
Hey guys I have the 3racing winch wired to a dx3 tx and a sr3000 rx with the winch power coming from a 9volt battery for mock up. Control the winch from contol pad or transmitter will only spool in? Tried reversing on the tx that only changed direction on the transmitter. I have the tx set on 3p with travel adj (f3)+ - @ 100%. Pleas help
nafie is online now   Reply With Quote
Old 06-27-2011, 09:47 AM   #2
Have you tried jumping power to the winch motor to see if it will work both ways?
Ernie W is offline   Reply With Quote
Old 06-27-2011, 10:21 AM   #3
ok just did that winch works so must be the control, right? What now?
Old 06-27-2011, 10:57 AM   #4
You've got a couple options on it, RPP Hobby sells the replacement winch controller for like $14 or a whole new winch kit for $25.....
http://www.rpphobby.com/category_s/424.htm
Or you could use a better winch controller which is what I plan on doing soon. A guy here on the forum makes them with different options.... they run off the 3rd channel like a servo, run off the reveiver or bec power.
Heyok's winch controller, they cost a few dollars more but from what I've read they are well worth it....
No Drift Winch Controller! (using 3 position transmitter channel)
Old 06-27-2011, 11:29 AM   #5
Thanks for the nice words of support guys!
heyok is offline   Reply With Quote
Old 06-27-2011, 12:09 PM   #6
Thanks guys just orderd one from heyok !
