08-15-2011, 02:11 PM | #1 |
Pebble Pounder Join Date: Feb 2010 Location: Calgary
| lose Steering
This is on a SCX10 with the stock AE1 speed controller, no BEC. Spectrum DX3C with the SR300 receiver that came with it. Servo is a Hitec 645mg. Every so often the steering is reduced or it doesn't steer altogether. If I reset the model and reset the endpoints all is good. Could it be a weak servo or possible a poor internal voltage let-through of the speed controller? I suppose it could be the transmitter but the set-up doesn't change and it doesn't seem to act weird in any other respect. |
08-16-2011, 10:43 AM | #2 |
Pebble Pounder Join Date: Jan 2008 Location: el paso
try using a capacitor from spektrum part number spm1600, maybe the rx could be wanting to brown out and that is causing the problem the capacitor plugs into any open port in the rx and holds a small amount of extra juice so that when the servo and motor are asking for more than what can be provided by the esc it does not loose reception.
08-16-2011, 11:29 AM | #3 | |
