10-11-2012, 11:55 AM | #41 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
| Re: I got some FXR ecs problems |
10-11-2012, 11:58 AM | #42 | |
| Re: I got some FXR ecs problems Quote:
10-11-2012, 02:44 PM | #43 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
Ok guys, let's settle this. The FXR does not auto-detect the voltage of any pack, nor set it's own LiPo cutoff. LVC 1 is off, LVC 2 is 6V (2s) and LVC 3 is 9V (3s). LVC 4 is custom cutoff, which is set in the HotWire. A proper voltage cutoff for a 2S battery would be 6.0V or higher and 9.0V or higher for a 3S. Setting the custom LVC to 3.6V would mean it would not cutoff power to the motor until the battery voltage dipped below 3.6V. It does not do it per cell and it certainly isn't magical. Are you 100% sure that after you set the custom LVC through the HotWire that it didn't somehow end up on LVC 3 for 9V cutoff? That is the only way it would work. |
10-11-2012, 03:05 PM | #44 | |
I will "assume" (yes, I know what that means) that the ESC goes by the "custom setting" and then decides if it fits a 1S, 2S, 3S, etc. PACK minimum voltage.) Just saying. | |
10-11-2012, 06:43 PM | #45 |
It's been so long ago that I set the LVC that I forgot how to do it. Getting old is hard on one's memory.
10-11-2012, 09:59 PM | #46 | |
10-12-2012, 04:57 AM | #47 |
10-12-2012, 07:29 AM | #48 |
Rock Crawler Join Date: Sep 2011 Location: truckee
10-12-2012, 08:09 AM | #49 |
