Thread: Mamba Max Pro help
Old 10-21-2011, 04:35 PM   #1
Default Mamba Max Pro help
I installed a MMP with a Tekin Redline 13.5 in my wraith. All went well and I was able to program my settings using the remote (spektrum DX3) and the procedure in the manual. But the settings wont save, or take affect. Am I missing something here? Do you have to save them somehow? At first I forgot to hook up the sensor wire from the motor to the esc and thought that might have been the problem. Then I hooked the wire up and still I can't get the settings to save.
Any insight would be a big help
hasbeen is offline   Reply With Quote
Old 10-21-2011, 04:50 PM   #2
One thing you could try is to reverse the throttle on your DX3. If it is normal, set it to reverse. If it is reverse, set it to normal. I forget which is correct but it may help your issue.
wantAsummit is offline   Reply With Quote
Old 10-21-2011, 04:54 PM   #3
Try rolling your firmware to an older version, then update it to the newest one. This helps most of the time, but in my experience once they start having this problem, it will need to go back to castle. BUT, try the firmware thing first. I like to run the oldest firmwares they seem more stable, to me anyway.
The Violator is offline   Reply With Quote
