Mmp vs rs Well, building a lcc shafty :ror: and can't decide if i want to go castle or tekin for the esc...curently i have a 17.5t redline, and it'll be getting a super torque rotor...i found it funny that they mention only use it in worm gear situtaions, or something that can handle the extreme torque...if the plastic gears in a lcc tranny can handle it, then why can't the plastic gears in another tranny handle it :???: Anyways I like tekin, tekin has always been good to me. But castle is a good option as well. So i can't decided if i want the RS (possibly pro) or the MMP. So whats the advantages and disadvatages for them (other than size, i was going to run an RX8 till holmes released his esc, but that trade took a unexpected u turn) Also MMP is compatible with tekin sensors right? |
The castle mmp comes with a much better warranty. that in itself would seal the deal for me. |
I have a MMP in my rustler with a 4600kv motor. it has ran excellent. no issues what so ever and has hit 69.6mph. I have heard about castle doing stress testing on them, their thermal protection kicks in at 256* from what i have heard. Hope that helps Rob |
I'm always on a tight budget, great thing about not having money is you shop smarter and cheaper... |
I used a Tekin RS in my LCC for two years and never had any issues with it. Worked each time and every time. You can't beat it for size, functionality and support. (Castle's is good but Tekin's is great). There isn't much room in a LCC chassis and the Tekin fit in it, not hanging off the rear, but in the chassis. The motor wires were like 1.5" long and used a 100mm sensor cable. |
A guy here (bigbird31) runs the tekin and I have the MM, soon to be the MMP. I think the only thing I can think of is the MMP can go to 6s, His has the bigger cap on it, so it can handle the 4S, but with no lipo cut off. other than that, I really couldn't see the difference in the tekin or the castle..both handled 3s and our motors very compairable. |
I'm just unsure about their low end sensored smoothness, how well their timing boost works, how easily they build heat, stuff like that |
I plan to do both. I have no experience with a sensored motor yet. but when i i do i can let you know. Rob |
I've been running MMP's in all three of my rigs since their release date and I have not had a Single complaint! No Heat(I don't even use the fan that comes with it), very good Startup, and it's the same size as the MM without the fan. Plus you already have castle link"thumbsup" |
Both need a external BEC. My rs pro has to run a older program so it doesn't fry CC 10a BEC's. The latest program made it smoother, but did no good when the BEC dies and loses steering. Rumors the CC 20a BEC holds up. Tekin's limited to about 30 degrees timing advance from the esc. Not sure what the boost adds to that? |
I think the Tekin ESC's work better with the Tekin brushless motors. There is a world of difference between my MMP and RS Pro. The RS is smoother, faster, and seems to run cooler. With a Pro4 brushless it's as fast with the RS on 3s as the MMP on 6s. I have had 2 MMP's go south but the RS Pro is only 4 months old, so time will tell. |
I love the MMP I used it in my lcc with the 17.5 motor as well and on 3s it was perfect. Both esc's are fully programable the MMP goes to 6s but 3s will be perfect. So its reall a toss up, but if you go MMP dont use the smart sense use sensored only mode the smart sense always glitched on me till i switched. |
I'm abit confused at how its possible, unless its back feeding power into the battery lines? |
As I said before I had a Tekin RS Pro in my LCC and used a Speed Passion 17.5 on 3S with a CC BEC for two years and many, many comps without a single glitch or problem. The RS is now in my 4wd buggy and it's the same one I used for mod TC. That's over four years of racing hard and crawling hard with the same ESC. |
Like Losikid said, I can't see how a firmware version in the ESC affects the external BEC. Frankly, I would run the servo direct off the BEC & the RX off the ESC BEC. If you have any glitch issues, connect the BEC black to the RX as well (along with the servo signal wire). |
