12-13-2011, 04:44 PM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: gastonia
| Uhhh do huh???
Ieght guys here my lil problem. Im not looking for people to solve it over the web just point me in the almost right direction please. When I turn left and only left and go full throttle of even sometimes just bump the throttle my servo glitches out and rips right.....My specs are as follows FXR on 3s CC BEC set to 7.1 or 2..can remember, Straight to servo Hobbyking HK125298B Traxxas HO 2.4 Tx an Rx...snipped about 1/4in off the Rx ant. was told it shouldn't hurt anything but the range The specs of the servo...HobbyKing R/C Hobby Store : HK15298B High Voltage Coreless Digital MG/BB Servo 66g / 20kg / 0.16s Could it be the servo demanding to much power, or just a SH***Y servo in general. Im kinda lost on this one so any help may work |
12-13-2011, 04:48 PM | #2 |
Rock Crawler Join Date: Mar 2006 Location: Up North
It's most likely that HK servo.
12-13-2011, 04:49 PM | #3 |
Is the bec grounded to the rx as well as the batt?
12-13-2011, 04:51 PM | #4 |
12-13-2011, 04:52 PM | #5 |
12-13-2011, 05:11 PM | #6 |
RCC Addict Join Date: Aug 2005 Location: SoCal
12-13-2011, 05:13 PM | #7 |
12-13-2011, 05:16 PM | #8 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
12-13-2011, 05:19 PM | #9 |
cool deal Ill get on it now..maybe after dinner |
12-13-2011, 05:27 PM | #10 |
| That was the issue...hacked in a wire plugged it up and bamm flawless Thanks guys for the quick responses and yeah fred I love this servo. it snapped my BTA spacer clean off the knuckle arm and wanted more |
12-13-2011, 07:43 PM | #11 |
Usually when there is a steering issue the "fixes" are: 1-external BEC 2-run the black or brown wire from the servo to the RX (mostly Spektrum radios) 3-check the steering EPA's to make sure you are not over driving the servo to mechanical limits In no particular order. |
12-14-2011, 11:31 AM | #12 |
For future search reference my issue was a glitchy servo with the EPAs set up right and direct wire from the back of the battery plug in to the power side of the BEC and the servo sides power wire(black and red ones off the BEC) directly to the servo and the signal(yellow or off color wire) to the Rx My fix was to unhook the battery side negative(Black) wire and plug it into the same port for your servos negative port on the Rx. Use your ESC plug in to determine what the signal and negative ports are for your servo. |
12-14-2011, 02:56 PM | #13 |
| whoa, so reading it the way you've written it here you only have the red wire from the BEC out hooked up to the servo? if so this is wrong. you will want the ground hooked up to the servo AND the RX.
12-14-2011, 04:36 PM | #14 |
| Re: Uhhh do huh???
on the BEC out side I have both hooked up..I took the negative off the battery deans and hooked it into the servo...Its glitch free and just as powerful..is that wrong |
12-14-2011, 04:57 PM | #15 |
| Re: Uhhh do huh???
like this |
12-14-2011, 05:18 PM | #16 |
| Re: Uhhh do huh???
yep mines wrong...Thanks for correcting that one |
12-14-2011, 06:16 PM | #17 |
| Re: Uhhh do huh??? |
12-14-2011, 06:18 PM | #18 |
| Re: Uhhh do huh???
Very true and I kinda like the dumbed down versions...makes me feel smart when I understand them...Thanks a lot for all your help.
