Thread: servos servos servos?
Old 11-21-2011, 07:03 PM   #1
Default servos servos servos?
So I have been looking for a new steering servo. I have a couple 645's but that are getting old and weak. I dont really want to spend a whole lot, so I have narrowed it down to a couple, I would like to know what you guys think.
savox sc-0251
jr 791 retract servo,
futaba s3051
hobbico cs-150
bikerpyro is offline   Reply With Quote
Old 11-21-2011, 07:12 PM   #2
hitec 7954
Krawler23 is offline   Reply With Quote
Old 11-21-2011, 07:17 PM   #3
I went all the way on my last servo Hitec HS-7980TH, and couldn't be happier!
Spendy but worth every penny!
Dogbreath is offline   Reply With Quote
Old 11-21-2011, 07:26 PM   #4
well they both seem like good servos, if I ever need 600 oz's I know what to buy. I am kind of on a budget.
Old 11-21-2011, 07:28 PM   #5
savox sc-0251
futaba s3051
hobbico cs-150
What is your intended use? What kind of rig?
For 2.2 comp I would recommend 300+oz if you are just messing around, if you are serious about comping 350+oz is in my opinion required...400+ is desirable.
For scalers it depends on the weight but you can get away with a lot less. I would say 200+ is a good place to be if you want good performance without spending much.
SMR 510RR is offline   Reply With Quote
Old 11-21-2011, 07:28 PM   #6
MODERATOR™
EeePee's Avatar
Not anymore!
HiTec 7950TH is what you need.
Definitely not the retract servo.
EeePee is offline   Reply With Quote
Old 11-21-2011, 08:00 PM   #7
very happy with my sc0251 on my honcho, granted thats using 1.9's and running the servo at 7v with a cc bec. Works great and runs cool so the voltage is all good, I found a spec sheet on savox's int website a while ago that spec'd it good to 7.2v. Been running it for a total of 20hrs like this and it is fast and strong on my setup.
kurtus is offline   Reply With Quote
Old 11-21-2011, 09:28 PM   #8
what is your budget and what have you narrowed it down to??
squatch71 is offline   Reply With Quote
Old 11-22-2011, 12:36 AM   #9
Ill be using it on a scaler, I have narrowed it down the list is in my first post.
Old 11-22-2011, 12:48 AM   #10
D-Wray 4 Prez!
Frankenwheely's Avatar
I have spent more with buying multiple cheap/reasonable servos again and again. Then when I finally bought a 7950, never looked back. Plus they stand by their products. I killed one, drove it to death, sent it in for repair. Couldn't fix it, sent me a new one at no cost.
Frankenwheely is offline   Reply With Quote
Old 11-22-2011, 01:31 PM   #11
savox sc-0251
futaba s3051
hobbico cs-150
Savox SA-1283SG. All the other Savox STD size servos are puny.
Best bang for bucks I've seen but depends on where you are.
reden is offline   Reply With Quote
Old 11-22-2011, 02:42 PM   #12
The 0251 servo is larger than standard size and all metal geared. Very strong for the value which I believe $40 is the most he wants to spend, i get approx 255oz at 7v and it's fast.
edit and it's digital. Is the futaba servo the s3051hv high voltage version.....only 158oz at 7.4v.
Old 11-22-2011, 02:48 PM   #13
i has a cs-150 on my sportsman truck and it lasted all of 20 mins before it stripped out. The cs-170 on the other hand is a very solid servo for the money been beating the hell out of one for a few years now not missing a beat. Id say go that way, but have also been pretty happy with my cheapo towerpro mg996r on my scaler strong gears and only 10 - 15 bucks since i use my scaler in water a lot i never really wanted to spend much on a servo, been holding up great all summer being abused.
mindless is offline   Reply With Quote
Old 11-22-2011, 07:42 PM   #14
thanks for all the info. Has anyone ran any of the hobby king servos? They have a mg hv and 280oz of torque.
Old 11-22-2011, 07:54 PM   #15
if you are on a budget get the 5645MG it is the digital version of the 645 it is kick ass, just put one in my scx10 and couldnt be more happy with it. think at my LHS it ran me 35$ give or take a couple pennies.
baconCHDDRchips is offline   Reply With Quote
Old 11-22-2011, 08:02 PM   #16
you know, I looked at your first post and didn't see your list.......
can't speak for the hobby king, but I have a couple of the towerdpro MG996R. and I just picked up a Savox sc1268
Old 11-22-2011, 08:07 PM   #17
cherry bomb
fred0000's Avatar
yes sir
I use this servo in my XR10 and so far i'm happy with it.
322 oz-in @ 6v
354 oz-in @ 7.4v
$65
HobbyKing R/C Hobby Store : BMS-2514 Coreless Digital Alloy Gear Servo - 25.5kg / 0.14s / 7.4V (High Voltage)
also have this one in my scaler and love it, this is the servo I also use in my 1/8 buggy and 1/8 truggy
249 in-oz @ 6v
277 in-oz @ 7.4v
$20
HobbyKing R/C Hobby Store : HK15298B High Voltage Coreless Digital MG/BB Servo 66g / 20kg / 0.16s
fred0000 is offline   Reply With Quote
Old 11-22-2011, 08:16 PM   #18
savox sc-0251
futaba s3051
hobbico cs-150
here you go
