Thread: horn screw for savox servi
Old 12-09-2011, 12:24 PM   #1
Default horn screw for savox servi
I bought a Savox seervi, SC-1268SG.
It only came with the two small screws to "pinch" the horn to the shaft.
The shaft coming out of the servo itself is threaded with somewhere between a 3 and 4 mm thread. ?????# tpi.
Does anyone know what that thread size is?? I've tried common metric and SAE threads with no luck.
Help!
Bob
Ellensburg, WA
Bob Wieking is offline   Reply With Quote
Old 12-09-2011, 12:28 PM   #2
Those are usually either 2.5 or 2.6mm.
JeremyH is offline   Reply With Quote
Old 12-09-2011, 06:20 PM   #3
Jeremy is on the money...some servos also use M3x0.5
WIDELOAD is offline   Reply With Quote
