12-16-2011, 08:38 AM | #1 |
Rock Stacker Join Date: Sep 2009 Location: Italy
| Bec novak m2
Hi, I tried to search the topic but found nothing, someone has the wiring diagram of the bec on m2? thanks Inviato dal mio GT-I9000 usando Tapatalk |
12-16-2011, 09:02 AM | #2 |
| Re: Bec novak m2
If you are asking about an external BEC to be used with the M2, it's no different than any other ESC.
12-16-2011, 09:11 AM | #3 |
| Re: Bec novak m2
Yes i asking about an external bec..i never install bec :/
12-16-2011, 09:20 AM | #4 |
| Re: Bec novak m2
Red wire of BEC input to red wire between battery & ESC, black wire of BEC input to black wire between battery & ESC. Option-1: Plug BEC output into open port on RX, remove red wire from ESC to RX and tape up. Option-2: Connect BEC to servo, run servo signal wire to RX |
12-16-2011, 04:07 PM | #5 |
Rock Stacker Join Date: Apr 2011 Location: Central, KY
To connect an external BEC on the M2 you have to remove both power wires (red) to the RX. Channel 2 (throttle) & channel 3 (dig), Novak has instructions on there web site.
12-17-2011, 11:47 AM | #6 |
| Re: Bec novak m2
Here is how I have mine M2 wired up: Is this what you are looking for? Just remember to remove BOTH red wires going from the M2 to the RX. |
12-18-2011, 08:27 AM | #7 |
Quarry Creeper Join Date: Mar 2006 Location: SoCal
| Re: Bec novak m2
Any M2Dig questions can be sent to Charlie, our Crawler expert: csuangka@teamnovak.com |
Bec novak m2 - Similar Threads | ||||
Novak or CC BEC....which one ??? | DORK VADER | Electronics | 5 | 03-11-2009 01:58 PM |
novak BEC | daleo8803 | Electronics | 2 | 10-07-2008 05:02 AM |
CC MM + Novak 6V BEC | srfrkyle1234 | Electronics | 0 | 08-31-2008 09:10 PM |
